One missing lug nut
Old Apr 28, 2010 | 10:04 PM
jsanders's Avatar
jsanders
Default One missing lug nut
I am about to take a trip and do not have time to replace a lug nut I twisted off on the right front wheel on my '84. Will this affect the driving and cause right front tire to be out of balance?
Old Apr 28, 2010 | 10:06 PM
jerryL98's Avatar
jerryL98
Probably won't hurt anything but I wouldn't feel all that safe at highway speed.
Old Apr 28, 2010 | 10:26 PM
jsanders's Avatar
jsanders
[QUOTE=jerryL98;1573911445]Probably won't hurt anything but I wouldn't feel all that safe at highway speed.[/QUOT
My lug nuts did not seem tight enough when tightening with my small tee handle lug wrench, so I put a pipe over the end to get more torque. That is how I twisted the lug nut off. I tried to remove the right front tire immediately and another lug nut collapsed so the lug wrench will not take it off. Any ideas how to get that nut off? I guess I feel safe at highway speeds since I tightened the other four nuts pretty darn tight.
Old Apr 28, 2010 | 10:38 PM
jerryL98's Avatar
jerryL98
There is a torque spec for lug nuts. If you got em that tight you might start breaking them as you drive.
Old Apr 28, 2010 | 10:41 PM
Sweet 90's Avatar
Sweet 90
I look at it this way, GM put 5 on for a reason
Old Apr 28, 2010 | 10:46 PM
jerryL98's Avatar
jerryL98
An excellent point.
Old Apr 28, 2010 | 10:47 PM
Frizlefrak's Avatar
Frizlefrak
Very intelligent engineers reasoned that they should be there. Good enough for me.
Torque them to spec and no more. I've never had one come loose, no less come off.
Old Apr 28, 2010 | 10:52 PM
RedLS1GTO's Avatar
RedLS1GTO
Holy chit... how much did you tighten those things???
I use stock GM lug nuts and torque lugs to about 120ft-lbs on the track car (ARP studs) and even with that I have never had one so tight that it "collapsed."
Old Apr 28, 2010 | 10:55 PM
Frizlefrak's Avatar
Frizlefrak
I'm thinking that cheater bar mighta pushed the envelope a bit.
Sweet 90's Avatar
Sweet 90
I don't know about the States, but any reputable tire place here will
torque your lug nuts for free, whether you bought your tires there or not.
Old Apr 28, 2010 | 10:58 PM
jsanders's Avatar
jsanders
I did not use a torque wrench so I do not know how tight. I used my small 1' X 1' tee lug wrench and put a 2' pipe over wrench. I was pushing about 2' from center of lug but did not push with all my strength.
Old Apr 28, 2010 | 11:16 PM
Pwnage1337's Avatar
Pwnage1337
2' pipe gave too much leverage apparently. The 1' tee lug probably would've been the best bet.
Old Apr 28, 2010 | 11:17 PM
wnafly's Avatar
wnafly
My manual says 100 ft-lbs.
Old Apr 28, 2010 | 11:42 PM
John A. Marker's Avatar
John A. Marker
should torque to 100 pounds. Take a few minutes and replace the stud and but. You can use a punch and hammer to knock the old stud out....be sure that you turn the disk so you have a small free area behind the stud for it to be driven out. Then put the new one in and rap it with a hammer a couple of time to seat it as well as you can. Then place a several washers over the stud and install a nut and tighten to 100 pounds. Install the wheel and torque all nuts to 100 pounds. Drive the car for 15-20 minutes and re-torque.
Check the torque for the next couple of days, sometimes it take a while to seat the stud.
Old Apr 28, 2010 | 11:51 PM
cal55's Avatar
cal55
I wouldn't risk it, it doesn't take long to replace a stud or lug nut. I had a stripped one I just replaced and noticed a few were changed already. I didn't drive the car until I replaced it.
Old Apr 29, 2010 | 12:42 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
What if you get a flat in BFE and havent made that repair?
Old Apr 29, 2010 | 07:04 AM
Joe C's Avatar
Joe C
the only trip i'd make in that 84 is one down to the repair shop. seriously, if you twisted one stud off with that cheater bar thing, the other studs are most likely in a weakened state. torque on threaded fasteners is a science in itself, and too often taken too lightly. wheels studs are pretty hefty pieces, and i can only imagine the amount of torque the OP applied. i would not trust the other wheel studs. taking this car on a trip - traveling at 60-70 mph on the highway - this scenario has disaster written all over it...
here's some good reading:
http://www.metalconsult.com/articles...20Failures.pdf
if it were my car, i'd be replacing all 20 wheel studs, and using a frickin' torque wrench!
Old Apr 29, 2010 | 07:15 AM
poor boy's Avatar
poor boy
I whole heartedly agree Mike! I've been in BFE in Central Nevada and had one lug that had been tightened with so much torque I couldn't break it loose so I had to get a piece of pipe I had in the truck and actually had to get a 9 o'clock and bounce on it while praying for it of break off so I could get the tire off, change it and get home.
Old Apr 29, 2010 | 07:34 PM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Just in case you bust one off?
To One missing lug nut
