Radar Detectors - worthless?
Old Mar 17, 2002 | 04:18 PM
Ender85's Avatar
Ender85
Default Radar Detectors - worthless?
I heard that Police radar has more than twice the range of the best detectors on the market - if this is true, then radar detectors are effectively useless. By the time they pick up any signal, the police already have your speed.
Is this true?
Old Mar 17, 2002 | 04:26 PM
Scoob's Avatar
Scoob
Default Re: Radar Detectors - worthless? (marthpodi)
If you are traveling alone - as in there are no other cars around - then likely any detector will be useless to you if the officer uses instant on to nab you.
However, if you are travelling with other cars around then the value in a detector is that you are able to pick up the signal being used against other cars ahead of you, thus giving you ample warning.
Old Mar 17, 2002 | 04:29 PM
crazyC4's Avatar
crazyC4
I'm looking into buying one for the summer. If they dont work I would take my chances on the road. :boxing
Old Mar 17, 2002 | 04:37 PM
Ender85's Avatar
Ender85
I hope to buy a C4 'vette very soon, and I am a high school student in a town populated by people with an average age of 65, so I am definately going to need a radar detector. Which kind do you recommend? best price/performance?
Thanks,
marthpodi
Old Mar 17, 2002 | 04:41 PM
jfb's Avatar
jfb
What you heard is not true. Police radar gun range is NOT farther than the detect range of a radar warning receiver. Here's why. Only a small percent of the police radar gun is reflected back to the radar gun and that reflection spreads out on its way back, getting even weaker while the warning receiver had the direct signal from the radar gun to cause an alert and this direct signal is 100 or more times as strong as the reflected signal from your car.
The Valentine 1 is the most sensitive radar receiver made and it tells you how many radar sources it is receiving and if the source is from the front , side , or rear. No other detector does this. Save your money until you can buy one. If you buy a cheap one, then when you finally realize you need the Valentine 1, then you will pay for only one detector.
[Modified by jfb, 2:44 PM 3/17/2002]
Old Mar 17, 2002 | 04:45 PM
Ender85's Avatar
Ender85
Default Re: Radar Detectors - worthless? (jfb)
Ah, that makes sense.
Old Mar 17, 2002 | 05:29 PM
Silver 96's Avatar
Silver 96
Default Re: Radar Detectors - worthless? (Scoob)
I think there is some minimum time required for registering your speed, because on two occasions I've been hit by instant on and was able to nail my brakes fast enough to idle past a glaring cop! :lol: :lol:
edit:
...and all I've got is a cheapie fuzzbuster!
[Modified by Silver 96, 2:33 PM 3/17/2002]
Old Mar 17, 2002 | 05:33 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
... the value in a detector is that you are able to pick up the signal being used against other cars ahead of you, thus giving you ample warning.
Thats without a doubt the best way to "use" a detector! ;)
Old Mar 17, 2002 | 08:03 PM
cprgmr's Avatar
cprgmr
My V1 has saved me many times. Not only in the vette, but in my daily drivers as well.
Old Mar 17, 2002 | 08:21 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
I have found that NO radar detector will protect me from my own stupidity...
Old Mar 17, 2002 | 08:39 PM
Lone Ranger's Avatar
Lone Ranger
Nabbed many that way :yesnod:
I would always rely on my eye to 1st judge if a target appeared to be exceeding significantly enough. If so, then instant on often worked quite well. The ones w/ detectors onboard, I could usually watch their front bumper dip as soon as I activated on them. Sure I'd loose 5 - 7mph of their true before-activation speed... before they jammed their brakes, but they'd usually still lock-in 15 - 20mph over the posted. Never messed with it unless I could lock them in at 15 or more over. 15 - 20 over and I would approach the stop with an open mind... respect and a little courtesy would get them a verbal warning. A 'tude would often yield a ticket. Not always, but most often. 20+ over and I would approach the stop planning on writing them up, but my mindset at times would be changed by the circumstances. I preferred to run radar in 45mph or faster posted zones. To me, popping people for 15 over in a 25 or 30 zone was chickensheet (unless a well posted school zone with kids out and about) To each his own, however, and some of the guys would.
Just a little from the inside. Haven't worked traffic in over 7 yrs though... CID now.
Old Mar 17, 2002 | 09:35 PM
VetteBabe1's Avatar
VetteBabe1
Default Re: Radar Detectors - worthless? (95_C4_convertible)
They use instant on a lot here in VA, I had a detector (which is illegal :cuss ) and got a 2 tickets...one with the detector and one without. But it did save me many times probably. Works good on a LONG straight road I found, I would get warning probably 3 miles before I passed the cop.
Old Mar 17, 2002 | 10:22 PM
STL94LT1's Avatar
STL94LT1
The Escort radar detector that I use to have was really good at warning me that I was GETTING A TICKET. It seemed like when it would go off, it was too late.
Old Mar 17, 2002 | 10:23 PM
IMXCITD's Avatar
IMXCITD
I have had very good luck with my V1 when traveling.....call it what you will. :)
Old Mar 18, 2002 | 12:40 AM
L98 punk's Avatar
L98 punk
I picked up a detector last year at Target, a Cobra for about $100. Since I have had it I don't know how I drove without one for so many years. I have picked up radar around bends in the road, from a mile ahead, and even when they come sneaking up from behind. I realize that anything other than a crystal ball is useless when you are really clicking along. But ,for those times when your speed drifts 10 -15 mph above the posted limit a detector can really save your tail.
:blueangel:
Old Mar 18, 2002 | 01:00 AM
Aerovette's Avatar
Aerovette
Default Re: Radar Detectors - worthless? (L98 punk)
I have one and I use it to make me a nervous wreck when I am feeling too relaxed. I have no faith in it. I have seen officers before the stupid thing went off. I would NEVER rely on one. Beeps and whistles and lights and ... Bah !
I use it to find out if there is a fast food place around the bend. :D :D :D :lol: :lol: :lol:
Old Mar 18, 2002 | 01:10 AM
McShagger's Avatar
McShagger
I really should get one... since my average highway speed is 85+mph where traffic permits. I havent got a ticket yet, and I know I deserve one since I drive fast. I really should get one....
I didnt think that they could get your speed from the side. Doesnt radar work with a cosign wave? It sends the waves out and gets a distance and rereads the the distance and computates the speed. In other words, they have to be reading from the back or the front. From the side, a speeding car will show no speed reading. Im pretty sure thats how that works. Can anyone correct me?
To Radar Detectors - worthless?
Old Mar 18, 2002 | 02:38 PM
ol,RJ's Avatar
ol,RJ
Default Re: Radar Detectors - worthless? (McShagger)
your right McShagger,
they don't work from the side, must be front or rear.
however its a nice feature on the V1. lets you know where the source is.
I just got a V1 3weeks ago. I think its the best detector I've ever owned, but I wouldn't rely solely on it to save my bacon. your eyes are your best defense.
If they have the radar on full time you'll pick them up easy. the instant on stuff will nail you if your the first car they shoot.
but with tickets costing around $100.00 or more each the $400.00 price of the V1 can be justified :yesnod:
I think If you run the same road over and over (like to work) the boggie counter is great! told me about 2 state boys hidden in a false alarm area ( I normally got 5 false alarms there, that day showed 7 ).
Old Mar 18, 2002 | 05:42 PM
Colbalt Blue's Avatar
Colbalt Blue
Default Re: Radar Detectors - worthless? (ol,RJ)
It's my understanding that Laser has to be in either the front of back
but won't give a good reading from the side; however, I've been told
that doppler effect radar works from all direction front, back, side or
top.
I have a Cobra, it has saved my butt many times but the most
important feature, in my opinion, is the emergency vehicle alert. It gives
an alert if there are emergency vehicles working in the near area. It
gives you a little extra time to access the situation, slow down and
give these good folks a lilttle extra space..
Old Mar 18, 2002 | 06:20 PM
Eric 96's Avatar
Eric 96
You shouldn't be speeding anyway....
Just had to say that! Hehehe
