Check engine no codes?
Old May 14, 2010 | 01:29 PM
rdknight's Avatar
rdknight
Default Check engine no codes?
My 89 keeps flashing check engine I checked the codes it shows nothing when I let out the clutch to slow down like when coming to stop light the light goes out until I push the clutch in.It runs fine any thoughts .
Old May 14, 2010 | 01:40 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old May 14, 2010 | 04:00 PM
Jamesnns's Avatar
Jamesnns
Wierd.....
Mine flashed it too today, went away after engine retstart.
Old May 14, 2010 | 05:44 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Originally Posted by Jamesnns
Wierd.....
Hey James was that before or after you hammered out those electrical problems today? Just curious...
Old May 14, 2010 | 06:06 PM
Jamesnns's Avatar
Jamesnns
It was after. CE was blinkig really sporatic (sp, thank you MDG.), kinda flickering.
Hasn't done it since, restarted at least 30 times..hasn't happened again.
No codes...I checked after it happened. Engine ran great, even with the flicker.
Ran at least 50 miles after, no problems.
I'll keep an eye on it. I'll toss it up to an annomily, cause I'm in a really good mood at the moment.
edit.
It might have been cause i ran some carb cleaner thru it to clean up the IAC. It was shortly thereafter when it happened.
Btw, after using some carb cleaner....removed air thingy in front of TB, I sprayed some in the small hole located in th bottom middle. My "surging" which wasn't very noticable cept to me, has since gone away. Mike form McInnis told me to do this. It worked.
Old May 14, 2010 | 06:23 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
edit.
Well if you had the desire you could try to duplicate it I guess but I'm with you. Stay in the “good mood” state of mind
Old May 15, 2010 | 01:37 AM
agintx's Avatar
agintx
Not to be a smartass, but are you sure you replaced the gas cap properly after your last fill up?
Old May 15, 2010 | 04:08 PM
rdknight's Avatar
rdknight
yes it has been doing it seen I bought it in January trying to work out the bugs it does have a locking cap maybe the gas cap is the problem?
Old May 15, 2010 | 04:31 PM
cal55's Avatar
cal55
Have you checked you clutch master cylinder, maybe it's low on fluid? I don't know if that would cause the light to come on but it's worth a look.
Joe
Old May 17, 2010 | 11:51 AM
rdknight's Avatar
rdknight
I changed the fluid.I drove it Sunday and it went out for about 5 miles then started flashing again.
Old May 17, 2010 | 01:31 PM
cal55's Avatar
cal55
Have you checked it since the light came on again?
Joe
Old May 18, 2010 | 06:17 PM
SunCr's Avatar
SunCr
Light is driven (grounded) by the ECM so that could be bad, but more than likely, it's got an intermittent short to ground on the ECM side which is Pin A5 or the Brown/White wire at the Display. Of course you will have to remove the Panel to troubleshoot the wire. There is also a possibility that it's at the Diagnostic Link, Pin B which is the ECM reference for Serial Data. When that wire is grounded to Pin A, the ECM flashes the Check Engine Light and after a Code 12, it spits out any other Codes that are Current or recorded in History. I'd make sure it can flash a Code 12 and then check the Connector to make sure that A & B are separated. People stick all sorts of crap in the Link to Check Codes and if the Plastic separating the Pins is broken, the terminals could be touching and lighting it up.
To Check engine no codes?
