Fuel Delivery Problem
History: Car seems to sputter out and die occasionally, but will start back up. Before this car ran fine.
Presently: Key on Engine Off, no fuel pressure at gauge.
Also no fuel pressure during cranking
Fuel Pump Fuse Good
Tried pounding on the tank, no luck
Cleaned ignition key off, no luck
1/2 tank of fuel
I dont know how to get 12 volts directly to the pump to check it so we can eliminate the relay. Where is the relay? Need a good write up on how to change fuel pump.
Any help would be appreciated.
