Trans Progress :D *pics*
Old May 17, 2010 | 04:44 PM
drmrman's Avatar
drmrman
Default Trans Progress :D *pics*
Pulled trans. Removed bell housing. removed pressure plate and clutch. Removed flywheel.
Installed fly wheel.
Then went to install the new clutch and pressure plate and the factory bolts are too long.
Eff my life. Nothing with this situation is right...
Old May 17, 2010 | 06:13 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
You're halfway there!
Old May 17, 2010 | 06:20 PM
Pete K's Avatar
Pete K
Wow.
Old May 17, 2010 | 06:27 PM
poor boy's Avatar
poor boy
Default long bolts
There is an excellent machine shop in Quincy IL. about 23 miles from me and they have a parts counter. If I need something special I usually check with them so you might check with the machine shops in your area. If they don't have it they may be able to point you in the right direction and usually not at dealer prices.
Old May 17, 2010 | 06:29 PM
mazdaverx7's Avatar
mazdaverx7
are the parts you're installing aftermarket or oem equivelant?
Old May 17, 2010 | 10:35 PM
drmrman's Avatar
drmrman
They are after market upgrades.
Spoke to the guy from carolina clutchs (where I purchased the flywheel/clutch/pressure plate from) and he said hes never heard of this problem before on LT1 vettes He said that this only happens with the LT5 zr1's... Strange... But we are sorting the issue out!
Old May 17, 2010 | 10:36 PM
drmrman's Avatar
drmrman
Originally Posted by Pete K
Wow.
I know... Can you believe that...
And know one I tell that is affiliated with GM believes me until I show them pics...
Old May 20, 2010 | 09:50 AM
drmrman's Avatar
drmrman
Ran into another snag... Factory pressure plate bolts were too short/long...
Old bolt. (factory)
New bolt.
Gap between the pressure plate and flywheel with the OLD BOLTS installed.
Old May 20, 2010 | 10:00 AM
5POINT7's Avatar
5POINT7
wow. best of luck gettin this tranny in. its lookin good.
Old May 20, 2010 | 10:48 AM
drmrman's Avatar
drmrman
Thanks man! Things been giving me hell! But Ive just been pooring water (money) on the fire to try to keep it out and just chug on through! Its been one mess after another with this thing!
Old May 20, 2010 | 11:26 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
Old May 20, 2010 | 02:15 PM
MR.LT1's Avatar
MR.LT1
C4 = Money pit!!! but what a nice feeling when you are all done and you know its been done right.......
Not bashing the C4 when I had a Mustang I was always spending money on it to upgrade it also.......so far you are looking good on your progress continue along...
Old May 20, 2010 | 10:17 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
I think you summed things up pretty well in your first picture!!
Old May 20, 2010 | 10:48 PM
drmrman's Avatar
drmrman
Yeah this sucks... Im sooooo close to finishing this project but I keep getting caught on stupid little snags!
Now I cant get the input haft to line up and slide into the pilot bushing... So the trans is a 1/2 an inch away from being installed but that last 1/2 inch has been giving me hell for 2 hours...
Old May 20, 2010 | 11:00 PM
SQUIRMIN VERMIN 84
I've been rereading your original post. It seems the only pieces different than before are the clutch disk and the pressure plate? Is that the correct pressure plate? using the original flywheel? can you find original part # of pressure plate and corresponding part # of pressure plate-to-flywheel bolts?
Old May 21, 2010 | 02:04 AM
rogerdoger1993's Avatar
rogerdoger1993
WAIT... I noticed there is a small section of the C-Beam still attached to your trans. Why did you cut it?
Old May 21, 2010 | 07:20 AM
drmrman's Avatar
drmrman
Notice the orientation of the bolts
Have a read
http://forums.corvetteforum.com/c4-t...s-install.html
To Trans Progress :D *pics*
Old May 21, 2010 | 07:21 AM
drmrman's Avatar
drmrman
Problem resolved with the new bolts.
New flywheel (alum)
New clutch
New pressure plate
New trans
Old May 21, 2010 | 10:51 AM
NitroNutt's Avatar
NitroNutt
Drummer,
What happened to the new trans? I know it was damaged and zfdoc was repairing it. What did I miss?
Old May 21, 2010 | 03:45 PM
drmrman's Avatar
drmrman
You missed the 2nd new trans
http://forums.corvetteforum.com/c4-g...n-all-4-a.html
