First corvette
Old May 20, 2010 | 12:32 PM
kim90's Avatar
kim90
Cruising
Default First corvette
I am getting a 90 vette in a few days, was wondering if anyone can tell me what to check out on it to ensure it is sound any weak points on this year it has 102k miles on it
Old May 20, 2010 | 12:42 PM
F22's Avatar
F22
Do a search on 'used corvette' or similiar terms. This subject has been covered extensively here.
Old May 20, 2010 | 12:44 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Or "corvette checklist". Congrats on your purchase.
Old May 20, 2010 | 12:46 PM
uptown193's Avatar
uptown193
I found this for you.
WHAT TO LOOK OUT FOR WHEN BUYING A C4 CORVETTE
-Look for floppy interior door panels when you shut the door. That's an expensive fix.
-Put your hand in and feel all around the floorboard carpet. You're looking for dampness, which is bad.
-Look at the outer window seal weatherstripping. They crack after a while, and they're $60 each, and a pain in the butt to replace.
-Look for abraded fiberglass on the underside rim edges of the hood, that's where a poorly-adjusted hood is wearing itself away on the bolt heads.
-Look for floppy ears on the sun visors. That's a nuisance.
-Look for missing ashtray and coin cup inserts in the console. Look for missing lighter. Look for missing top ratchet wrench in the console.
-Look for the lug nut wrench behind the driver's seat. Look for evidence that it's been used.
-Look for shiny spots in the black 'rubberized' interior trim.
-Look for abraded leather seat bolsters and sill carpeting.
-Especially watch for worn-out carpet over the footwell speakers. This is critical, because foot-dragging in and out of the car wears them out, and they are no longer available from ANYONE. Grrr...
-Look for chunks missing out of the windshield weatherstripping. Examine the windshield seal at the very base of the windshield on the INSIDE of the car. It gets cracked and crappy.
-Look at the frame directly behind the driver's front wheel. This is directly under the battery tray, and C4s tend to rust here first, if at all. Ask to take the gill panel off if they'll let you, you'll need a 10mm wrench and a Torx set.
-Get in the car and sit in both seats, and operate ALL of the seat controls several times.
-Look in the storage compartment behind the passenger seat and check to make sure the package tray is in there.
-Check the color and condition of as many fluids as you can get to - PS, oil, tranny, coolant.
-Lie on your back and look over at the rocker panels. They get sandblasted over the years, and look worse on dark-painted cars.
-Check the parking brake for good operation. Check the hood release.
-Check the RPO codes to make sure that the car isn't missing something that should be there. Specifically, "C2L", which means that it should have BOTH tops, because it came that way.
-Run the A/C and the Heater, make sure you get both, especially with the C68 electronic climate control.
-Look for a floppy tilt steering wheel. Put the wheel down in driving position, then try to flex it downward. If it moves more than a smidge, it's going to be a problem sooner or later.
-Look around all the interior trim, A-pillars, halo trim, etc. for missing screws.
Check exhaust system for nicks and/or missing hangers(why are they missing?)
-Pull out the seat bottoms and look for anything under the seats(ie cut wires,food etc).
-check the locks in the console and hatch compartments, make sure the key you have works in those locks.
-if equipped with PKE, check all operations of it
-look for the jack, later C4's have it in the passenger side compartment in the hatch, earlier ones, in a bag within the spare tire
-check rear tire tread, low or no tread means the previous owner drove it properly.
-check wheel orientation, make sure right rear is on the right rear etc, if unsure, pull the wheel off(early C4's had the location stamped on the inside).
-make sure you have two lefts and two rights(wheels)
-check tire orientation, make sure they are rotating in proper direction.
Power seats - do they work?
Power mirrors - do they work?
Power antenna - does it work?
Look for oil leaks around the valve cover gaskets
Check the Air filter element and the casing for it
See if that optional $895 Bose stereo works and all speakers are working properly.
- Try the key in both door locks to make sure the lock is working properly.
- Make sure the digital dash is working properly, try all of the gauge readings by using the switches (i.e. temp/voltage, mileage instant/mileage avg., etc).
- Check to see if the headliner is intact and not starting to sag.
- Check the popup headlights a few times to make sure the gears are working and not sticking.
Check condition of serpentine belt.
Check condition of hoses.
Look for leak on rear diff.
Check play on all 4 wheels for possible hub bearing failure.
Check condition of glass top if equipped. Look for cracks or peeling in clear coat.
- check intake manifolds. oil leaks for all years, coolant for L98s.
- oil on the oil pan. could mean a front main or bad pan gasket.
- belt tensioners
- on 1992-93e, the belt is 2 sided, make sure it is good shape, and buy 2 when you order!
- rear window defroster. that is an annoying thing at times.
Check the DIC for proper lights with ignition is in the on position (Batt, SES, etc.). Check that ABS is active at 3mph. Pull codes to see what is in the history.
- make sure if its a 4+3 that the OD works correctly
-check the suspension for signs of wear
-make sure winsheild wipers and switch work in all speeds
-check for al interior screws
-Check for back Glass fit.
Check to make sure the stupid electronic climate control actually works, and doesn't have a mind of its own!
_______
1984-1996 Corvette – Average cost to replace items:
• 1984-1996 Carpet without insulation backing — $460/complete set
• 1984-1996 Carpet with insulation backing — $500/complete set
• 1984-1996 Door Panel Carpets — $50-100/pair
1984-1996 Standard Leather Seat Covers — $700-750/set
• 1984-1996 Standard Vinyl Seat Covers — $350-375/set
• 1984-1996 Standard Seat Foam — $300/set
• 1984-1996 Sport Leather Seat Covers — $700-750/set
1984-1996 Aftermarket Acrylic Panel — $1100
• 1984-1996 GM Restoration Part Acrylic Roof Panel — $1250
• 1984-89 Dash Cluster Repair — Usually around $1500-$1800 if repairable
General:
Q: What should I look for in a Corvette?
A: First of all, wait for the "perfect" vehicle for you. Don't rush out and buy the first vehicle you look at. You should consider all of the factors on this site and decide what you are looking for in your Corvette and what you want out of it. If you want a mint vehicle you will have to spend more money. If you want something in a reasonable price range you may have to compromise and take a few imperfections to be fixed later (see Corvette Parts for considerations.)
Q: Should I buy a Corvette as an investment?
A: Corvettes usually retain their value and early models increase in value, however there are many other investments that will give you a faster return. The webmaster believes that this vehicle should be enjoyed and not simply stuck in a garage to collect dust while hoping for a return on an investment.
Q: Should I buy a Corvette that is a real "fixer upper"?
A: The cost of restoration of a needy vehicle often exceeds the predictions of an overenthusiastic buyer. Unless you plan on doing all of the labor yourself and investing a lot of time and money, this often turns out to be more of a burden that a pleasure. This is especially true in later models where there is a large selection of vehicles to choose from that aren't so needy.
Q: Do I need to consider if the numbers match?
A: Corvettes with the original motor and original parts hold their value better than those that don't. Also vehicles with lower VIN numbers tend to be more valuable, especially in earlier models. If you are simply looking for a vehicle to enjoy and not as an investment, matching numbers aren't as high on the list of factors you should consider.
Q: Do I need to know the history of the vehicle?
A: Whenever possible try to find out the history of ownership, repairs, alterations, etc. Save all of your paperwork so that you can pass the information along when you sell the vehicle. This information can add to the value of your vehicle.
Although Corvettes tend to hold their value more than most vehicles, it is not a good idea to buy one solely as an investment. This is a vehicle that is meant to be enjoyed!!
Q: How do I know if the car I bought has it's original options?
A: RPO codes are the production codes for the vehicle. They will tell you all the factory options that the vehicle came equipped with. If you don't have a copy of the build sheet and/or window sticker, you should check to see if the option list still remains inside your car. Common placement in a C4 includes under the center console and inside the storage bins. In a C5 you can find it inside the glove box. If you cannot find this sticker inside your vehicle you can try to find the build sheet. The build sheet is the exact specifications for the vehicle including all the RPO codes, the build date and shipping destination. Starting in 1967 the build sheet was glued to the top of the gas tank. Prior to 1967 there is little documentation to prove how original a vehicle is, except to check for a manufacturing date on the parts. In C3s, the build sheet has also been found rolled up and stuffed on top of the steering column and on top the heater box. The tradition of glueing the build sheet to the gas tank continued on through the C4, but many C4s also contain more than one copy of the build sheet. Starting in 1997, on the C5 the build sheet is in the front "bumper" frame rail, the front facia must be removed to access it.
Buying a Corvette
Buying your first Corvette can be a difficult task if you're not sure what to look for. You've heard all the terms, "matching numbers", "body-off restoration", "frame-off restoration" etc. but you're not sure what they mean. Our goal here is to provide you with a little bit of knowledge before you go into the Corvette buying world and to supply you with a handy check list of items that you may want to check out the Corvette that you're interested in purchasing. Depending on options, some of the items on the list, may or may not apply to the particular Vette that you're looking at. Hopefully, we've compiled a fairly broad enough array of items to look at that will cover just about all Corvette model years.
Below, are a few of those definitions defined and we've added the checklist for you to take a look at.
Matching-Numbers: By far, this is probably the most commonly used term you will ever see when it comes to buying a Corvette. Many owners claim that their Corvettes are matching numbers, but many owners fail to have a good understanding of what the term truly means. Most parts on a Corvette come with serial numbers and date codes. Often the serial number of the part will also contain the date code in which the part was manufactured. An example would be the engine code found on the Corvette's engine block. This code can identify the engine's origin and date of manufacture. The term, "matching numbers" implies that all parts on the car are numerically correct and the date of manufacture of those parts are correct for that Corvette. For example, if you're looking at a 1969 Corvette with a 427ci. engine and the engine stamp indicates that the engine was built in early 1968, or even late 1967, that Corvette cannot be called a "matching-numbers Corvette". As parts break and need replacement, many owners, purchase the parts they believe are correct for the car, when in fact, numerically, they may not be. If you're in the market for a "numbers matching" Corvette, and you're not familiar with identifying build codes and date codes, you should probably take someone along with you that is knowledgable in that area.
Body-Off Restoration: Simply refers to the fact that the Corvette was restored and the body was removed from the frame in order to conduct a thorough restoration.
Frame-Off Restoration: Although slightly misleading, this term is the same thing as the above "Body-Off Restoration".
General Assessment
Model Year: ___________ Model: ___________________________ VIN: ________________________
1. Owner name: _________________________ Phone #: __________________
2. Exterior Color: _______________ Interior Color: ___________________
3. Mileage: ___________
4. Reason for selling the car? ________________________________________ _________________________
5. Documentation available? Window Sticker Build Sheet Protect-O-Plate None Miscellaneous:__________________________ ________________________________________ ______________
6. Are maintenance records available? Yes No
7. Who maintained the car and where?_______________________________
8. Are maintenance or upgrade receipts available? Yes No
9. How many previous owners have there been? _______
10. Can the former owners be contacted? Yes No
11. If so, what are their names and phone numbers?
________________________________________ ________________________________________ __
12. Is it currently registered? Yes No
13. Does it have a current inspection sticker? Yes No Will it pass state inspection? Yes No
14. Are there any modifications? Yes No List them:
15. If equipped with standard transmission, has the clutch ever been replaced? Yes No When? Where? What mileage?________________________________ ______________
16. Has the car ever been in an accident or had bodywork done? Yes No Why?
17. Has the car been kept garaged? Yes No
18. What have been the average driving conditions? (Sun only, rain, snow?) ________________________________________ _______________
19. Does the car need anything now? Yes No If so, what? ________________________________________ ___________
Body Condition
1. Does the car sit level? Yes No
2. Check body panels for uniformity. Pass Fail
3. Check for body damage. Look at: Wheel wells, floor pan, rear hatch (pull up carpet), front and rear valance, fenders, quarter panels, uniform body molding. Check for paint over-spray in: headlights, gas door, door jams, fender skirts, engine compartment?. Is there evidence of body damage? Yes No
4. Is the paint oxidized Yes No Some oxidation
5. Has the car ever been repainted? Yes No
6. If so, why, by whom, and how long ago? ________________________________________ ______________
7. Does sides of the car appear aligned? Yes No
8. Are there any waves or stress cracks in the fiberglass? Yes No
9. Are there any dings or stone chips in the paint? Yes No
10. Are there any cracks or chips in the windshield or side and rear glass? Yes No
11. Do the doors open and close normally? Yes No
12. Do the doors and trunk lock and unlock correctly with the key? Yes No
13. Do the doors and trunk (if applicable) lock/unlock correctly with remote key FOB (if applicable)? Yes No
14. Does the rear hatch glass open properly? Yes No From inside? Yes No
15. Do the struts hold the rear hatch? Yes No
16. Does the hood release work? Yes No
17. Does the color match the trim tag color code? Yes No
18. Are there missing badges, or moldings? Yes No
Chassis & Suspension
1. Are the tires in good condition? Yes No Cracked or signs of dry rot? Yes No
2. Is tire wear uniform. Yes No
3. Are the wheels stock? Yes No What type of wheels? _______________
4. Are the wheels in good condition? Yes No
5. Are the brake rotors in good condition? (check for cracks or scarring) Yes No
6. Are there any wet spots under the car? Yes No
7. Are the rubber axle boots in good condition? Yes No
8. Inspect the tie rod ends and ball joints. Pass Fail
9. Inspect the shocks. Dry Wet If the shocks appear to be wet, they may be leaking and in need of repair.
10. Is the exhaust in good condition? Yes No
Interior Condition
1. Are all door, hatch, and top seals in good condition? Yes No
2. (If applicable) Is the ratchet wrench for the targa top there? Yes No
3. Are the seats clean? Yes No Torn or cracked? Yes No Worn? Yes No
4. Can you adjust the seats? Yes No
5. Is the carpet clean? Yes No Worn? Yes No
6. Can you adjust the mirrors? Yes No
7. Does the interior light work? Yes No Does it work with the doors? Yes No
8. Is the dash in good condition? Yes No
9. Is the center console in good condition? Yes No
10. Does the glove compartment door work properly? Yes No
11. Do the windshield wipers function properly? Yes No
12. Does the overall interior condition match the mileage? Yes No
13. If equipped, does the tilt wheel work properly? Yes No
14. If equipped does the alarm work? Yes No
15. Does the clock work? Yes No
Engine Evaluation
1. What type of engine does it have? __________________________________
2. Is it original? Yes No
3. Is the oil clean? Yes No Dark or black colored oil indicates a change is necessary and may be indicative of past maintenance trends.
4. When was the last oil change? ______________ Overdue? Yes No
5. Check for a leaking oil pan gasket. Pass Fail
6. Check for a leaking front/rear main seal. Pass Fail
7. Check the master cylinder and slave cylinder for leakage. Pass Fail
8. Check all coolant lines for leakage. Pass Fail
9. Check the coolant in the reservoir. A brown frothy mixture in the reservoir usually indicates oil and water mixing in the oil filter/cooler housing. Pass Fail
10. Inspect the fuel lines going to the fuel rail for brittleness or cracking. Pass Fail
11. Inspect the plug wires for brittleness or cracking. Pass Fail
12. Inspect the brake fluid for color. Black colored brake fluid indicates a change is necessary. Pass Fail
13. Is the air filter clean? Pass Fail
14. Is the engine bay clean and neat? All hoses / wiring in correct place? Pass Fail
Engine Operation
1. Does the car start properly? Yes No
2. The car should have a steady idle. Pass Fail
3. (If equipped) Check the ECM (computer)? Engine Codes recorded? Pass Fail
If so, what are the codes? __________________________________
4. Is the oil pressure normal? Pass Fail
5. Engine coolant temperature: Normal? Yes No High? Yes No Fluctuating? Yes No Fluctuating coolant temperature may be indicative of a necessary water pump replacement.
6. Is there valve chatter or excessive engine noise? Yes No
7. Is there excessive engine vibration at idle or revving? (can indicate bad motor mount). Yes No
8. With the engine running, listen for leaks at the exhaust manifolds and exhaust. Pass Fail
9. Does the heat work? Yes No
10. Does the AC work? Yes No Is the compressor quiet? Yes No
11. Does the AC / heater blow at each speed? Yes No
12. Does the radio work properly (tape and CD if applicable)? Yes No
13. If equipped, does the power antenna work? Yes No
14. If equipped, do the power windows and door locks work? Yes No
15. Does the defroster work properly? Yes No
16. Do all ***** / controls function correctly? Yes No
17. Do all of the gauges / dashboard lights work properly? Yes No
Test Drive Evaluation
1. Does the parking brake work properly? Yes No
2. How does the brake pedal feel? Firm Soft
The following 3 questions assume manual transmission:
3. How does the clutch pedal feel? Firm Soft
4. Does the clutch operate in a smooth quiet manner? Yes No
5. Does the shifter seem tight? Yes No
6. Are there any squeaks / noises (specially over rough roads)? Yes No
7. Is the steering smooth and responsive? Yes No
8. When going straight is the wheel straight? Yes No Does the car drift to one side? Yes No
9. Brake with your hands off the wheel does the car stop straight? Yes No
10. At highway speeds does the car pull, or shake / shimmy? Yes No
11. Does the cruise control work properly? Yes No
12. Is there exceptional wind noise? Yes No
13. If equipped, does the ABS system function properly? Yes No
14. If equipped, does the Traction control system function properly? Yes No
15. If equipped, does the Selective Ride Control function properly? Yes No
Miscellaneous
1. Is the battery in good condition? Yes No
2. Do all lights / signals work correctly? Headlights?, (high and low beams), Yes No Brake lights: Yes No Parking/Side Marker Lights: Yes No Turn Signals: Yes No
Standard Equipment: ________________________________________ _______________________
Optional Equipment: ________________________________________ ___________________________
Price / Value
Asking Price: _____________
Retail Value: _____________ Trade-In Value: _____________
Notes:
Old May 20, 2010 | 06:26 PM
HlhnEast's Avatar
HlhnEast
WOW! If Ida had this I probly wouldnt have bought mine!
Old May 20, 2010 | 06:46 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
Yeah the checklist is brutal but doesn't leave much unturned...
Old May 20, 2010 | 06:48 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Uptown has it covered. Good Job
Old May 20, 2010 | 09:06 PM
uptown193's Avatar
uptown193
Yea and I think the guy who wrote that.
Old May 21, 2010 | 07:00 AM
MyFirst90coupe's Avatar
MyFirst90coupe
Yeah, I woulda never bought mine if I had that checklist
Old May 21, 2010 | 08:36 AM
Churchkey's Avatar
Churchkey
Have a 90.
The only issues I have encountered other than standard maintenance items are:
INFL reset light, this is the air bag warning light & normally involves removing the left & right frame rail sensors to clean the corrosion from the sensors & the attaching points on the frame. Plenty of info & how to's on the forum.
Multi tech fuel injectors, if they have not been replaced just do it. Contact Jon @ FIC here on the forum.
Bose radio/tape/CD speakers & speaker amps. If its not broke it probably will be. Pricey to repair.
Headlight door motors, the drive pins in the gears deteriorate & will need to be replaced. This is a common problem on C4's.
If its a 6 speed the trans will be noisy idling in neutral with the clutch out + if you hear a knocking noise from the bellhousing area when idling its the dual mass flywheel. The engine is skipping 1/2 a beat. Changing the injectors will probably cure it.
The LCD display tends to get sun faded & wash out.
A factory service manual is a necessity if you plan on doing the service on the vehicle.
Check the RPO codes listed on a sticker under the center console door.
Z51 = performance suspension.
FX3 = selective ride control
J55 = heavy duty front brakes, 13" rotors instead of the standard 12" rotors.
Good luck & post some pix when you get it.
Old May 21, 2010 | 01:01 PM
RedVette84's Avatar
RedVette84
Ask if a member is close by and can go along or meet you there when you look at it. Most of us love to window shop and don't mind giving a opinion or looking at a car. I've looked at few for other folks. Save the Wave.
Old May 21, 2010 | 01:13 PM
Y-ME's Avatar
Y-ME
That checklist is overkill and no 20 year old driver could pass it.
Check to see if tire iron was used???? Come on!
Old May 21, 2010 | 04:26 PM
poor boy's Avatar
poor boy
That's why I bought an '86, just two questions on my check list:
1.) Does it run?
2.) Is it drivable?
Old May 21, 2010 | 04:48 PM
Jon Hekking's Avatar
Jon Hekking
Originally Posted by poor boy
That's why I boughjt an '86, just two questions on my check list:
1.) Does it run?
2.) Is it drivable?
Afterall, even with the checklist, look at all the work Uptown had to do on his...... makes you wonder.
Old May 21, 2010 | 04:55 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
1.) Does it run?
2.) Is it drivable?
Old May 21, 2010 | 05:06 PM
1st87's Avatar
1st87
you put alot of effort into that list-good job....i agree with other poster-sat in her, started her up, adjusted the mirror, and drove her home.........
Old May 23, 2010 | 09:15 AM
pane056's Avatar
pane056
Default Checklist
WOW!!!! An understatement.
I have no doubt that none of the 5 vettes we looked at would have passed this checklist, not even close. But then I wonder. Would any 17 year old anything pass it or even come close??? I printed it off but don't plan on using it now for fear of learning just how big a mistake I made buying it.
First, I drove it with the owner. Then a test drive with the wife. We both drove it. Checked the tires, the engine compartment, fluid levels, looked on the garage floor for leaks, checked the convertable top, the body and that pretty much was it. We made the deal. Drove the car home, about 110 miles. Everything seemed o.k. The headlight Hi Lo beam switch does not work. Probably will replace the turn signal switch. Last weekend we went for a drive, probably close to 200 miles, down secondary roads. We both were very happy. Turned quite a few heads. Probably the sight of a fat old fart with a lovely young chick in a beautiful car made folks wonder how I pulled it off.
This forum site is wonderful. The information obtained is priceless.
Thanks, nicholas
To First corvette
Old May 23, 2010 | 09:44 AM
Churchkey's Avatar
Churchkey
Congrats!!
"The headlight Hi Lo beam switch does not work. Probably will replace the turn signal switch."
Have not worked on the Vette high beam switch however on other GM models:
The high beam switch is located on the left side of the steering column. It is adjustable, move it up toward the steering wheel.
Good luck.
Old May 23, 2010 | 09:57 AM
olcrusty's Avatar
olcrusty
"Churchkey" is not a very good name for car members
Old May 23, 2010 | 10:21 AM
Churchkey's Avatar
Churchkey
HA!
Glad to have you back! Your wit has been missed.
I take it you remember canned man beverages before pull tabs & pop tops? Just like a good boy scout I was always prepared & carried the proper can opening tool.
