Why Vin #
Old May 24, 2010 | 01:31 PM
txtode's Avatar
txtode
Default Why Vin #
Going to order some parts from a vendor on E-Bay and they requested the last 8 #'s of the VIN #. I thought the last 7 were the sequence #. The 8th from the end is the letter M. What info would that give the vendor.
Old May 24, 2010 | 01:36 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
The M is the year, but the last seven are the unique build sequence (the "serial number"). They should want the first 10 to see if it's a coupe or convert, and which engine you have. The only thing meaningful they get out of the last 7 are whether it's an early or late build.
Old May 24, 2010 | 01:42 PM
txtode's Avatar
txtode
That's what I wanted to know. Couldn't figure why they needed the sequence. But the year I can understand. I told them the year and model at the gitgo.
Thanks for the answer.
Old May 24, 2010 | 01:45 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
I believe last 8 is model year, production plant, 6 digit serial number.
We always used last 8 in the dealer parts system as the database had specific build options for each serial number. What option packages, etc.
Old May 24, 2010 | 03:54 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Why are you saying "number" twice?
Old May 24, 2010 | 04:10 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Old May 24, 2010 | 05:13 PM
ch@0s's Avatar
ch@0s
the important ones are the last 8
Old May 24, 2010 | 08:20 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Same reason people say NIC card.
Old May 24, 2010 | 08:54 PM
ch@0s's Avatar
ch@0s
most people wont get that
Old May 24, 2010 | 09:13 PM
WVZR-1's Avatar
WVZR-1
There's enough information in your "signature" for "SOME" to probably decode and post your complete VIN!
The vendor undoubtedly has access to RPO decoding from the VIN and would like to confirm he's selling you the correct parts!
Does the vendor have another reason for the inquiry? Who knows!
The first 8 of your VIN should be enough for an "intelligent" parts "professional" to do parts for your '91 unless you're interested in "trim"!!
C@0s mentioned: the important ones are the last 8
Actually all 17 are "important"!!
Old May 24, 2010 | 09:52 PM
txtode's Avatar
txtode
Thanks to all for the replies. Saying VIN # is just habit.
ch@0s's Avatar
ch@0s
When you are buying a part.
Fownd this in another thread:
There are 17 characters. Starting with the first character on the left:
1. 1 = built in the US
2. G = General Motors
3. 1 = Chevrolet
4. Denotes the car line. Corvette is a Y body.
5. Provides more info about the car.
6. Body style. 1 is a FRC, 2 is a coupe, 3 is a convertible.
7. Restraint code
8. Engine:
L98 = 8
LT1 = P
ZR1 = J
LT4 = 5
LS1 = G
LS6 = S
LS2 = U
LS3 = W
LS7 = E
9. Check digit - 0 to 9 or X
10. Model year:
B through N are years 81 to 92
P = 93
R through T = 94 to 96
V = 97
W = 98
X = 99
Y = 00
1 through 9 is 2001 through 2009
11. build plant Bowling Green is 5
12. Production sequence number that starts with 1 for each model year.
To Why Vin #
