Need help with digital dash!
Old Jul 6, 2010 | 11:00 PM
JCDVette's Avatar
JCDVette
Default Need help with digital dash!
Digital part of dash keeps going in and out. (1993) I look online to see if I could find parts to replace it of to get a idea of what could be wrong. I dont think that I found anything talking about the digital part of the dash. I could not even find a layout of the gauge part of the dash. If anyone has a web site that has parts to fixs this or videos or anything that will help please let me know.
Thanks, Jason.
Old Jul 6, 2010 | 11:06 PM
jhammons01's Avatar
jhammons01
dig into the website Batee.com
It's a guys personal website so be patient and look.......he has the most comprehensive step by step do it yourself fix it for your cluster.....
Takes about 3 hours of time to complete...but it is an easy task
Old Jul 6, 2010 | 11:14 PM
JCDVette's Avatar
JCDVette
I went to the site but that was for a older model. thanks for the help thow.
I guess that I should have said that I needed help on a 1993 C4 model.
Thanks again.
Old Jul 7, 2010 | 12:43 AM
jfb's Avatar
jfb
The Batee site is the only place I have ever found info on the C4 cluster. If you have no experience repairing electronic circuit boards it would be best for you to leave this to cluster repair places. Apparently GM sold rights to do repairs to C4 clusters and will only sell parts to these stations and left the owners out in the cold. With no knowlege of circuit board repair techniques, you could damage beyond repair, your cluster.
Old Jul 7, 2010 | 02:41 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Unless you have reasonable skills with with a soldering gun.....
Old Jul 7, 2010 | 02:55 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
As with most intermittent problems, one of the first checks would be the grounding..
Old Jul 7, 2010 | 03:45 AM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Cold solder joints especially, degrade and years of vibration don't help.
Old Jul 7, 2010 | 06:16 AM
JCDVette's Avatar
JCDVette
Do you know where it is grounded at? Or how to go about cheaking it?
Old Jul 7, 2010 | 09:57 AM
jhammons01's Avatar
jhammons01
JCD, when folks say "grounding" problem...folks think about a single wire that has corrosion on it.....
....on a PCB, (printed circuit board, or the green board with components soldered on it) a grounding issue comes in the form of large components hanging from a board that is mounted at a 90° angle from the ground......so these large components are hanging....and for ~15 years and 100K miles these things have been wriggling up and down from bumps and gravity......eventually the solder that holds them in place gets old and cracks.
Now you have a spot where electricity is shorted....or not making contact anymore. This explains why your cluster "sometimes" works. You hit a bump in just the right way and the system blinks "on" or "off" depending.....
All you have to do is......With a soldering gun.....you re-heat the solder joints holding the components in place. This old solder "re-flows" and the connection is made whole again. You then move to the next component.
It takes about an hour to do the whole board...My famous story is that I R&R'd my cluster during a Sunday night Football game.
Ah c'mon....if a replacement is $300-$500 on Fleabay and a repair is $300-$500........isn't a wash? I mean, if the guy learns something in this process, wouldn't fixing the thing for less than $50 be worth the gamble??
It's like this, My Son working on his Eagle Scout project had to break up soil similar to if you were prepping to plant a garden.
Being here in SoCal, He's never even had to run a weed eater, much less use a shovel.
During the process, he and about 6 other Scouts learned what it takes to turn over a 16' x 20' plot of raw dirt.......
I couldn't help...only supervise.....it was painful watching these guys "figure" it out, but I could give advice. eventually they figured it out.
So, saying "Take it to a shop" well that is a default response, we are all here to "avoid" taking it to the shop.
Old Jul 7, 2010 | 10:27 AM
JCDVette's Avatar
JCDVette
I working on removing the cluster and I am using haynes repair manual. It is telling me to remove the Knee bolster and trim panel, then remove the steering column bolts and lower the column.
Well I believe that I have taken off the "bolster" and the "trim panel" even though it is not pointed out what those are. But I have no clue to where these "column bolts" are or how to lower the column.
Can anyone help please!?
Old Jul 7, 2010 | 11:00 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Thanks, Jason.
Sound like your LCD panel is bad.
Old Jul 7, 2010 | 12:13 PM
lourib727's Avatar
lourib727
I have a 93 like yours. I did not have to lower the steering wheel. Just remove the lens, that gives you move room to wiggle the cluster out. I just replaced the lights on mine. Good Luck
Old Jul 7, 2010 | 01:21 PM
JCDVette's Avatar
JCDVette
Well I had to lower the column to get the plastic piece out from in front of the lens. My bulbs were fine. Just that stupid digital part that was messing up. but i took it out and then put it back and so far so good. If it goes bad I will most likley make my own dash that works. lol but this one has done good for 17 years i have to give it that.
Old Jul 7, 2010 | 01:43 PM
1985nightmare's Avatar
1985nightmare
I had the same problem with my 85. I looked for months online for a fix. You can buy a repair manual but then you need to buy an electonic tester and then the parts and you still might not get it right. There are a few guys online who will repair it for a somewhat reasonable cost but of course you have to send your unit to them and if there is a problem then it might become a long drawn out affair with you paying the shipping cost every time. I went to GM and they sent my dash out to get it fixed. It cost $600 but the work was gauranteed and it only took a week. Anyone who owns a digital vette is going to face this problem, it's just a matter of time. No use trying to save a few bucks on this one.
Old Jul 7, 2010 | 01:59 PM
jhammons01's Avatar
jhammons01
^^Huh?
Everything you said, contradicts everything I said.
Especially on an '85......Go to Batee.com and even if you don't have tools, you can fix your cluster for $50, that includes buying a soldering iron and the proper size nut driver.......and it takes about three hours of your time.
Not $600 and a week.....
Old Jul 7, 2010 | 03:04 PM
wpfn's Avatar
wpfn
I agree with jhammons01, however results may vary based on your technical ability and specific problem. Mine took 2 hours and cost $30 for an 89.
Old Jul 7, 2010 | 03:33 PM
Chuck Tribolet's Avatar
Chuck Tribolet
A soldering GUN is going to be WAAAAAY too powerful
and physically too big for these tiny components. You
need a small soldering IRON, preferably one that's
thermostatically controlled. You also need a steady hand
(NOT the thing do the morning after a pub tour) and
reading glasses.
To Need help with digital dash!
Old Jul 8, 2010 | 11:59 AM
1985nightmare
^^Huh?
Okay I checked out your website, and it doesn't really show you how to do anything! There are a lot of suggestions about what may be the cause for this or that symptom but no real solutions, and lets get real here unless you are an electrical engineer do you think you can identify a diode from a capacitor and read one of those schematics that he posted? C'mon, If you took the backs off the clusters and just did a few solders here and there then you just got lucky...And by the way I have fixed everything on my vette myself from power window motors to the alarm system, brakes, valves, power seats, water pump, power mirrors, injectors and the list goes on, but this was beyond my skills.
By the way I needed a new power supply in the cluster, retail price $175 if you can find one, if you know where to get one!
Old Jul 8, 2010 | 12:25 PM
wpfn's Avatar
wpfn
Default Try adding something useful?
Odd, I'm sure that the batee.com website has helped thousands of corvette owners with little or no knowledge of the dash, much like myself. Instead of simply complaining about the information provided, perhaps you could possibly add some some value to this thread? FYI -I'm no EE and can easily ascertain what the difference between a diode is and a capacitor, if for no other reason, simply because I can read.
Old Jul 8, 2010 | 01:51 PM
jhammons01's Avatar
jhammons01
You must be joking or you can't seem to follow a few links
Does this look like a "General suggestion" to anyone with an I.Q. above room temps??
Originally Posted by batee.com
Tools you'll need for this project
To remove the Digital Cluster:
- 9/32" 1/4" drive socket
- 1/4" drive ratchet
- 1/4" drive 6" length extension
- #2 Phillips Screwdrivers, stubby and regular length
- 1/4" Straight Blade Screwdriver
To service the Digital Cluster:
- 7/32" Nut Driver
- 25-40W Pencil Soldering Iron with pointed cone tip ($5.99 at Radio Shack - don't use soldering guns or higher heat soldering irons! If tip of the iron isn't clean, smooth and tinned, don't use it - you'll damage the circuit boards)
- .032" Rosin Core (Electrical) 60/40 Solder
- Solder wick/braid (just in case you make a mistake soldering)
- Windex / Cloth paper towels (While it's apart, you might as well clean it)
- Canned / Compressed air (Dust, bugs collect inside the panel)
- Static control wrist strap (radio shack again)
- Electrical contact (tuner) cleaner (not brake cleaner, which leaves behind a non-conductive lubricant
- Replacement bulbs for any illumination lights that are burned out. They're available at GM dealership parts counters. The part number is #882 or #891.
Removing the Digital Cluster
1. Using a #2 screwdriver, remove all the screws holding the Digital Cluster Bezel to the dash. There's one behind the vent that you'll need a stubby screwdriver to remove.
2. Place the tilt steering wheel in its lowest position, then remove the steering wheel tilt lever by unscrewing it. Use a wrench if necessary, but be careful not to mar the surface.
3. Remove the four 9/32" Hex head screws that hold the instrument panel to the dash. There's one at the top left and top right corners, and two above the steering column.
4. Tilt the top of the Digital Cluster out away from the dash. There's a sharp metal cover on the back of the instrument panel. Be careful not to scrape this on the column, the dash, and be careful not to scratch the Digital Cluster LCD display panels on the column.
5. Using the flat blade screwdriver, remove the clips securing the two electrical connectors on the right side of the Digital Cluster, and remove the electrical connectors.
While the Digital Cluster is out
1. If you have further troubleshooting to do, now is the time to do it. Many test procedures outlined in the Chevrolet factory shop manual for Corvettes require that the Digital Cluster be removed, so if something else isn't working, now's the time to fix it.
2. Clean the lower dash area and bezels. You can never get into all the cracks and crevices with the bezels in place, so clean them while they're out. You'll be glad you did.
Disassembling the Digital Cluster
IMPORTANT: Wear the properly grounded static wrist strap the entire time the Digital Cluster is apart! These were built in the mid-80's, and as a result, contain CMOS semiconductor components that are extremely sensitive to static electricity.
Figure 1 - Back of Digital Cluster
1. Place the Digital Cluster face down on a soft surface and remove the five 7/32" hex screws holding the metal panel to the rear of the panel. Remove the metal cover. See Fig 1.
Figure 2 - Back Cover Removed
2. Remove the seven 7/32" screws holding the top circuit board to the Digital Cluster case. Two of these are found on the back side of the long black electrical connectors leading to the wiring harness. See Fig 2.
3. Disconnect the odometer wire and carefully remove the top circuit board.
4. Remove the three 7/32" screws holding the odometer to the instrument panel case and remove the odometer. Please try to resist the temptation to tamper with your odometer at this point. I'm sure there's a law somewhere against it.
5. Remove the 22 screws holding the bottom circuit board to the Digital Cluster case.
Figure 3 - Housing with both circuit boards removed. I had to remove the odometer in order to reassemble the Digital Cluster
6. Be very careful at this point! There's no physical connection between the glass lcd displays and the bottom circuit board, but when you lift the bottom circuit board, the LCDs might come with it. Also be careful not to touch any of the lamps. Residual oil on your hands can dramatically shorten the life of these already extremely hot lights.
7. The pink and grey rubber blocks between the glass LCD displays and the bottom circuit board are conductive, and are the "wires" connecting the glass to the curcuit board. There's no glue on either end, they just kinda tend to stick to the glass and the copper traces on the circuit board. See Figure 3.
8. If it hasn't happened already, separate the LCD displays (3) from the bottom circuit board. If you have a segment out, go ahead and remove the pink/grey rubber blocks from both the glass and the circuit board. If not, try to let them remain stuck to the glass. Try to keep the panels, thick clear plastic light diffusers and thin plastic color sheet together. Don't worry about maintaining their alignment at this point - there are index pins to line everything back up when you reassemble it. Fee Figure 3.
Repairing the Digital Cluster
1. Carefully clean the faces of the glass LCD panels with Windex and paper towels. Mine had a ring of silicon around them, courtesy of the former owner.
2. If you have a segment missing, remove the pink/grey rubber blocks from the LCD panels and thoroughly clean the edges of the blocks and glass with windex. Be careful - the edges of cut glass are sharp. See Fig 3.
3. Clean all parts with compressed air to remove residual dust, bugs, etc. All this crap IS conductive to a certain degree and can potentially cause a short circuit.
4. On the bottom circuit board (the one you took out last) resolder the joints on the connector that connects the two circuit boards. See Figure 4 and 5.
5. Resolder the joints on the other large components that appear in Figure 4 - The capacitor (big yellow thing), the brown resistor, and the voltage regulator (black thing with three leads) are all susceptible to broken solder joints due to the fact that they support large components or high current carrying ones.
Figure 4 - Board Interconnector (front view)
Figure 5 - Back of Bottom Circuit Board - Board Interconnect is in the lower right corner
Some notes on soldering
* When soldering, heat the connector lead and the solder pad on the circuit board, not the solder. Once these two locations are sufficiently heated, solder will flow into the joint. Don't just heat the existing solder, add a small amount of new solder to each joint. The rosin it contains will help to clean the solder joint and help the solder stick.
* Cold solder joints take on the following forms in this case:
o Dull grey / crystalline appearance: Reheat the joint and add a small amount of solder until the joint is a bright shiny concave pool around the connector lead.
o Rectangular outline around the connector lead: Reheat the joint and add a small amount of solder until the joint is a bright shiny concave pool around the connector lead.
o A convex (water drop look) bead of solder around the joint: Use the solder wick to remove the old solder (there's too much). Place the wick over the solder to be removed and heat the top side of the wick. When it's hot enough, the solder will flow from the connection to the wick. Then resolder the joint.
* Solder bridge: This is when a drop of solder spans two or more connections. This needs to be removed. Use the solder wick to remove the old solder (there's too much). Place the wick over the solder to be removed and heat the top side of the wick. When it's hot enough, the solder will flow from the connection to the wick. Then resolder the joint(s).
6. I didn't find any cold solder joints on the top circuit board connector, but while it's apart, you might as well resolder them too. See Figures 6 and 7.
7. User tip from John Dernar (jdernar@nordson.com): My display would go dead any old time. I ran a new ground wire and even hot wire to the incoming harness, but it eventually went dead again. I examined all the connectors and solder joints under a microscope and still didn't see a problem. Finally, with the guts under power, sitting on top of my dash board, I was able to make it die on me. As it turned out, one of the large capacitors on the power supply board had a cold joint (or probably had been shaken loose) and was causing the whole problem. I hit all the solder joints with the iron and haven't had a problem in about a year. How could they expect large components to stay attached under such conditions?
Authors notes: The power supply board is pictured in Figure 6 (the one with the cylindrical orange things). Be careful of that ribbon cable - if yours doesn't have a connector (mine didn't), be careful not to pull it loose from the larger circuit board - it's a really short cable! Remove the board and resolder everything. It's quite a few connections to solder, but it'll be worth it in the long run. You don't want to have to do this again, do you?
Figure 6 - Top Circuit board interconnector with power supply piggybacked (Front View)
Figure 7 - Top Circuit Board Interconnector (Back View)
Figure 8 - Top Circuit Board Full View (Front View) - Power supply board is the board in the top right corner.
Figure 9 - Top Circuit Board Full View (Back View)
8. User tip from Bill Blake (bblake@idmail.com): Add a wire from the tip of the ground pin for the halogen lamps circuit to the nearest solder point along the same trace. This acts as insurance against a bad solder (cold) joint in the future.
Following photos provided by Bill Blake:
The part Bill added was the black wire
9. Clean the circuit board connectors on the top and bottom circuit boards with electrical contact cleaner.
10. Thoroughly clean the instrument panel housing inside and out.
Reassembling the Digital Cluster
Caution: When assembling the LCD displays verify that it is inserted and down flat between those alignment tabs. It could be missed if the unit is sitting on a pad or towel that could leave it raised up a bit. Seriously - there have been two reports of problems concerning LCD panel damage during reassembly, so be careful!
User Re-assembly Warning from Bill Blake (bblake@idmail.com): The person before me must have had it all apart. He then assembled it by not noticing that the glass LCD module needs to sit down in the correct location as determined by the positioning tabs around the edges of the glass. You mentioned that it all goes together easily with proper alignment tabs etc. It certainly does but this guy must have been in a hurry. He left one side cocked up on two of the square shaped tabs alongside the edge connector. When the remainder of the assembly was screwed down it crushed the LCD display. This left two half moon shaped shattered glass spots on the edge connector of the LCD display. This of course wiped out the connections embossed on the glass at that spot. I figure there are at least a dozen connections all told that are destroyed.
User Reassembly tip by CorvetteForum reader Jan-Erik: A very good advice. Do not touch the rubber that makes the contact between the display glasses and the lower pc board. Then you can lose some of you segments in the display. If you do you have to take the rubber and the plastic foils above the glasses up and clean it with pure ethanol or alike. Clean the rubber also. Then install it again and everything will be ok. I would recommend to change the bulbs when you have everything out. It is extremely easy to do it when you have the cluster out and you have removed the upper pc board.
The following series of pictures were provided by Bill Blake: Speedometer LCD panel showing damage that can occur if not properly aligned
Before reassembling the cluster
* Clean all surfaces of the LCD panel and bottom circuit board with Ethanol or high-grade isopropyl alcohol. This includes the conductive part where the pink rubber blocks rest. Also clean all surfaces of the rubber blocks and don't touch the surfaces where the rubber and glass meet. The oil residue can cause segments not to work.
* If you're missing segments in your display, remove all rubber blocks from the glass and PC Board and clean all mating surfaces of the rubber blocks and the glass with alcohol.
* Heed the warnings above! Be careful - the images show how wrong things can go if you don't. You have been warned.
Reassembling the Cluster
1. Place the glass LCD displays into the Digital Cluster housing. There are numerous rubber and metal clips used to precisely position these panels. Make sure you don't pinch them between the glass and the panel housing. Be sure the LCDs are positioned correctly and right-side-up.
2. Place the plastic trays that position the pink rubber blocks onto the backs of the LCD panels.
3. If you removed the pink rubber blocks, place them back in the plastic trays after cleaning the mating surfaces of the rubber, glass and bottom circuit board with alcohol.
4. Replace thin plastic colored sheet.
5. Replace the three thick clear plastic pieces (see Fig 9).
6. Replace the bottom circuit board. Start all 22 screws before tightening, then be sure to tighten them evenly.
7. Replace the odometer.
8. Replace the top circuit board. Be sure the pins from the bottom circuit board are aligned with the holes in the bottom of the top circuit board.
Figure 10 - Housing with both boards and odometer reinstalled
9. Reconnect the odometer lead to the top circuit board.
10. Replace the metal back cover onto the instrument panel housing.
Figure 11 - Back Cover replaced.
Reinstalling the Digital Cluster
1. Reconnect the instrument panel to the two electrical connectors. Test functionality before reinstalling.
2. Just reverse the steps above when you removed the panel to reinstall it.
Congratulations! You're done!
A Note From Bryan
I've spent a good part of the last nine years crreating, compiling, and producing the information above, and I hope that it helped you to resolve a problem. If so, it probably saved you between $300 and $500. Consider clicking here and donating a $20 to keep the information free.
Thanks,
Bryan A. Thompson
I'm starting to understand why your '85 seems to be a "nightmare" while my '84 is a joy to drive and tinker with......
