C4 Maintenance..
Old Jul 7, 2010 | 02:43 PM
AC13's Avatar
AC13
Default C4 Maintenance..
Hey whats goin on? I just have a quick question to ask regarding maintenance. What can I do to try and keep my 95 in the best shape possible. I know about frequent oil changes but what else do you guys suggest to do both now and when I put the car away for the winter.
Thanks for the help.
ac
Old Jul 7, 2010 | 02:47 PM
fc_soldier's Avatar
fc_soldier
You can grease all the fittings on your suspension. Replace bad weatherstripping. Clean alot. You'll find alot of things to do and alot of problems if you spend the time and know every inch.
Winter add a trickle charger and fuel stabilzer. Make sure your coolant has a 50/50 mix or 70/30 mix coolant being the higher percent. Put carpet peices under tires to avoid flat spots.
Old Jul 7, 2010 | 02:53 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Yup. And on the preventive maintenance tip, stop by your local hardware or plumbing supply store and get a big tube of Pool & Spa Lube. Apply with your fingers. It'll keep your weatherstrip moist and supple for many years to come.
Old Jul 7, 2010 | 03:26 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Fresh coolant, weather strip maintenance, and the correct tire pressure
Old Jul 7, 2010 | 05:55 PM
94z07fx3's Avatar
94z07fx3
I'll just add that it never hurts to make sure the drains are clean. The door bottoms have drain holes as well as the drain behind the fuel fill. White litium grease sprayed onto the hinges and the hood latch too.
Old Jul 7, 2010 | 05:58 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Check all hoses and especially the rubber portion of the fuel lines
Old Jul 7, 2010 | 05:59 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Here is a Super Tune Up check list for a C4 L98. Much of this will apply to your LT1 and will be a good start. You can modify the electrical section to include your Opti unit.
File Type: pdf
Old Jul 12, 2010 | 05:01 PM
AC13's Avatar
AC13
Thank you guys for all the information. As usual you been a great help
To C4 Maintenance..
