Help help ignition problem
Old Jul 14, 2010 | 11:11 PM
Shawnksf's Avatar
Shawnksf
Default Help help ignition problem
so today i went to start the vette (92 base coupe Lt1) i got in the car the inside lights came on the dash lit up when the key was put in then i turned the key and nothing happend. next thing was the center cluster went completly out but the center consol stayed lit. after a few seconds the center LCD screen came back to life, i tried the key again and the car turned over but wouldnt start. i had a 14.2 volt charge on the battery so that wasnt the problem. then after turning the key back to off and turning it on againit would again turn over but not start. then again the LCD went out and it wouldnt turn over. yet the radio and center console were still powered. after about 10 minutes of poing around with no idea what was going on standing on the side of the street in a suit lol i tried the key again and she started. any ideas whats going on?
ps i turned the car on and off when i got home a few times and it worked perfectly
Old Jul 15, 2010 | 08:37 AM
Shawnksf's Avatar
Shawnksf
no one has a clue? cuz i sure dont
Old Jul 15, 2010 | 08:48 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
I dont either. Any codes? I would check that all my ground wires are tight?
Good Luck,
Mike
Old Jul 15, 2010 | 09:03 AM
lt4obsesses's Avatar
lt4obsesses
If, when she did finally start, everything worked well, I would look at the battery forward. It is possible that over time and with vibration that the terminal connection could be just loose enough to cause this. Good enough connection to light interior lights but not enough to engage the starter.
Then follow the wires, checking grounds, connections. There could have been some condition, dirt, moisture, etc. at the starter connection that prevented initial start.
Your battery could be nearing the end of it's life. Though it reads good charge on the gauge, it's cranking power could be falling off. If it's getting on five years that's about the time they go.
Finally, it could be the starter itself. The clutch spring that engages the gears to the flywheel/flex plate could be getting ready to go. But that's a long shot and your symptoms lend more to electrical.
Old Jul 16, 2010 | 12:26 AM
jfb's Avatar
jfb
The center console may not be related to your no crank problem. One thing I would do and it is easy. Remove the battery cables (neg first) and clean the cable lugs, bolts, and battery terminals and then replace the cables (neg last). Batteries need a very low resistance connection in order to be able to supply the 100+ amps the starter requires and cable connections get flakey after 1 or more years.
Old Jul 16, 2010 | 01:34 AM
Shawnksf's Avatar
Shawnksf
Thanks for all the ideas guys. So today after work I went to test if the vette started and no dice. My partner is working nights so he wanted to listen if there was any sound when the key was turned. So I tossed him my spare keys and the car fired right up. After a few tests we figured out it's the key itself the security chip was so worn out the connection was bad the key turned the car to on but wouldn't engage the ignition. So problem solved!!! Thanks for the help guys!
Old Jul 16, 2010 | 01:55 AM
lt4obsesses
Hopefully you found the trouble. You might try hitting that chip on the key with a little rubbing alcohol. Happened to me once, turn the key and nothing. After a few tries and nothing, I thought it might be the vats. cleaned the key with some alcohol and whala.
The thing that would concern me, is that as I understand it, when the chip voltage is not correct or present, the ingnition is completely disengaged. In your original post you spoke about the car cranking but not starting. I could be wrong, but vats would prevent the car from cranking.
Old Jul 16, 2010 | 09:18 AM
Shawnksf's Avatar
Shawnksf
welli will keep that in mind it seems fine now so we will see
thanks
Old Jul 17, 2010 | 01:15 AM
Shawnksf's Avatar
Shawnksf
UPDATE!!
so the car started fine this morning and started fine when i left work. i parked to get some food and when i got back to the car it wouldnt start. after a few minutes the dash seemed to click back on then the car started. after a few block of driving annd the dash lights went out and the interior lights as well. the analog guages still work but the LCD is out when i open the door the lights inside dont come on either.....SO WHAT THE HELL
Old Jul 17, 2010 | 02:44 AM
lt4obsesses
UPDATE!!
Did the dash lights go out while you were driving, or after you stopped? If they went out while you were driving, you probably have a short somewhere in the dash, or a loose ground. If they went out after driving and the car was not running, I would first go back to the battery connections. Been there, done that too. Had an occasion when I would turn the ignition key then everything would go black. Discovered my negative battery wire connection was stripped, caused it to do this randomly.
Old Jul 17, 2010 | 02:37 PM
Shawnksf's Avatar
Shawnksf
the dash lights went out after the car was driving but the analog stayed working as well as the display on the radio just the lights went out on the center console and the LCD in the dash + back lights went out. plus now it wont start. when i turn the key the brake light and the check gauges light is on. the center info display works as well but it is saying service ASR
Old Jul 17, 2010 | 07:30 PM
Shawnksf's Avatar
Shawnksf
does anyone know where the voltage regulator is?
Old Jul 17, 2010 | 07:43 PM
LannyL81's Avatar
LannyL81
voltage regulator is in the alternator.
Check the battery cables....pull back the red and black plastic ends and take a good look at the cable.
Old Jul 17, 2010 | 07:48 PM
Shawnksf's Avatar
Shawnksf
i will check it. but would the cables being loose or bad still allow the radio and allow the engine to run while all the other electronics went out? plus when i puch up the dimmer the light inside comes on but when i open the door it doesnt
Old Jul 19, 2010 | 01:34 PM
Shawnksf's Avatar
Shawnksf
so more update.first off i dont have a obd reader to get codes and the car isnt running enough to get it to the shop. it starts when it wants to but after a few minutes the dash lights and LCD screen go out completely. after you turn off the car it wont start. i cleaned up the battery and after reconnecting the cables it started fine then went out again
Some one was saying check the vats.....i dont know what that is or where it is help? could this possibly be an alternator problem as well? yesterday while the dash was on i watched the volt meter(while the car was on but not cranked) run from 14.9 to 11.0 in about 30 seconds.
if it is electrical this car may be for sale soon
Old Jul 19, 2010 | 02:09 PM
Louiseven's Avatar
Louiseven
I am certainly no expert but it sounds like you may want to have your alternator checked out too. You say the voltage is fluctuating perhaps the alternator is own its way out. I"d check the the battery cables end to end as well.
Old Jul 19, 2010 | 02:14 PM
j-vette's Avatar
j-vette
St. Jude Donor '10
To Help help ignition problem
Old Jul 19, 2010 | 02:26 PM
Shawnksf's Avatar
Shawnksf
Originally Posted by j-vette
no popcorn!!!!! i'll make you popcorn if you come help
Old Jul 19, 2010 | 08:52 PM
ezspdr's Avatar
ezspdr
Something similar happened to me. The car would fire up every day then once in a while would not start. I would leave the car for 30-40 minutes, come back and it would fire right up. The guy who is changing my A/C system out looked at it and it was the battery. The battery had loose posts. The battery is being changed out as we speak.
Old Jul 19, 2010 | 09:01 PM
NitroNutt's Avatar
NitroNutt
Good Luck,
Mike
I agree with Mike. You have several on there.
