Disconnect ESC Module?
Old Jul 23, 2010 | 10:57 PM
ejscarfo's Avatar
ejscarfo
Default Disconnect ESC Module?
OK, I know I read something about this in the posts, but for the life of me, I can't find it again. I remember seeing something about disconnecting the ESC for a few minutes and plugging it back in for the computer to relearn, etc. Does this ring a bell to anyone, and if so, why do you generally do this procedure?
Old Jul 24, 2010 | 12:23 AM
Pwnage1337's Avatar
Pwnage1337
I thought for the computer to "re-learn" you disconnect the battery for a minute then reconnect it.
Old Jul 24, 2010 | 10:27 AM
Aardwolf's Avatar
Aardwolf
The computer doesn't self check the ESC till coolant temp is 195°. Then it adds timing till there is knock. If you want to reset things just disconnect the neg battery cable for a min.
Old Jul 24, 2010 | 12:08 PM
redrose's Avatar
redrose
that clears codes and a few other minor bits...to do a 'hard reset', do three x : key on for 15 sec with no engine run, key off for 15 sec.
if your vette has a stock engine and stock prom and running 1/4 mi., a 'hard reset' at the end of the staging lane just prior to actual run will likely result in better perf than even the 'learned' ecm resets from the return road cruise.
Old Jul 24, 2010 | 01:25 PM
ejscarfo's Avatar
ejscarfo
Sounds good. I may just give it a shot.
To Disconnect ESC Module?
