CAR overheating!
Old Jul 24, 2010 | 02:32 AM
Waspination's Avatar
Waspination
Default CAR overheating!
Driving with my date and so happen to look at the coolant temp... 240 and rising. Hit 260 and got to where i needed and shut it off.
Hours later... Went to leave and it climbed very fast again. So my buddy was there to help; We got coolant, put it in, about the whole gallon. Temp comes down but still lots of smoke out of pipes and clanking noise comin from where the main cat is. WEll temp goes normal.
I Had to get this girl back to her car. About half way there, temp slowly rising. Mind you every time i took off from a stop... lots of smoke from pipes, then would clear. By the time i get there it hits 255 and burn smell comes along. I shut it off.
She leaves, it pouring rain on me, crazy storm. Finally my buddy picked me up and gonna get it towed in the morning and have my buddies look at it.
What a night Friend suggested head gasket
Old Jul 24, 2010 | 05:10 AM
CMYC4GO's Avatar
CMYC4GO
Head gasket would be my first guess, but if you pegged the temp. needle and the temp kept climbing before you got it shut down...god only knows what other damage you might have done to it.
This date of yours must be a world class piece of tail in order for you to destroy your car in order to get her back to hers. Fix your car, and enjoy her..."charms" or fix your car, and find a not so "all about me" girl.
Old Jul 24, 2010 | 06:55 AM
1st87's Avatar
1st87
change your thermostate- i went from a 195 to a 180. what a diff it made the car run alot cooler..temp doesn't go over 215 now...also make sure your radiator fan is cycling on. it should come on at like 215-220 degrees...good luck
Old Jul 24, 2010 | 07:21 AM
cv67's Avatar
cv67
St. Jude Donor '05
Shes a chick so its her fault the car overheated anyways.
Shoulda done her
In the butt just for that then tossed a 396 crate motor on her credit card. Gotta train them sometimes, yessir.
Old Jul 24, 2010 | 07:31 AM
CMYC4GO's Avatar
CMYC4GO
Shoulda done her
Too funny for words!!! In the butt no less...only you could come up with that!
Old Jul 24, 2010 | 07:33 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
BULLSEYE! Good advice on all subjects.
Old Jul 24, 2010 | 07:56 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
I agree, with all the smoke you probably did a head gasket.
Need to find out why it is getting hot too...were your fans on? I had a relay go bad on one of my cars so the cooling fan didn't come on when needed.
Old Jul 24, 2010 | 12:42 PM
Bronze85's Avatar
Bronze85
Coolant in the combustion chamber is NFG most likely a head gasket as a result of another cooling syst. problem.
Old Jul 24, 2010 | 01:17 PM
Jon Hekking's Avatar
Jon Hekking
Probably more than a head gasket at this point, that was most likely the result of pegging the temp gauge. There's some underlying issue I would think. The fans would be high on the list of suspects..............
Old Jul 24, 2010 | 01:21 PM
hooked073's Avatar
hooked073
Head gasket leaking into cyl causing you to loose coolent then you overheat, add coolent leak eats more coolent overheat. Just replace head gaskets. flush fill and you should be fine. I would have heads checked if mine but usaly not a problem.
Old Jul 25, 2010 | 02:08 AM
Waspination
Fans work fine, ive checked them days before. About month ago posted that coolant was mysteriously low and had not leaked in garage... and no one could figure it out. Hadn't had coolant problem again till last night so must of just really gave in.
Got it towed today. When car came off the bed, i saw blue/green water that had dripped from the tailpipes, so theres coolant getting in the engine no doubt. Oil looks good though.
So since we are takin the engine apart... gonna do the main seals too cuz its had a slight oil leak too. MAybe take the cats off too if we can, may be damaged and hey, why not get the performance gain.
Old Jul 25, 2010 | 08:30 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Its probably leaking from the intake into a cylinder(s) and burning off. I had the same problem with my 85 a LONG time ago. New intake gasket set will take care of that problem.
Old Jul 26, 2010 | 06:32 PM
vetdrem's Avatar
vetdrem
Shoulda done her
I love it!! Lmao!!
Old Jul 26, 2010 | 08:15 PM
Chuck Tribolet's Avatar
Chuck Tribolet
I'd pull the heads, get them checked for straightness
(lap if not straight, maybe lap on GPs.), and do new
head gaskets.
How many miles on the heads? If they are off, a good
multiangle valve job might be a good idea. And do
the valve stem seals.
Chuck
Old Jul 26, 2010 | 08:41 PM
Casket86's Avatar
Casket86
Shoulda done her
Old Jul 26, 2010 | 11:32 PM
CStewTAMU's Avatar
CStewTAMU
I'd also check the radiator. The core can get clogged over time with mud, rust deposits, etc. Especially the lower horizontal tubes. That can gradually reduce the radiator's efficiency.
Old Jul 27, 2010 | 09:39 AM
Chuck Tribolet
On further reflection, I'd first pull the spark plugs and
see which ones are wet or unnaturally clean (a leaky
head gasket steam cleans them). Post back the results.
To CAR overheating!
Old Jul 30, 2010 | 01:45 PM
Waspination
pulling the plugs, good idea, ill see if i can.
Well heres my options and need your guys opinion, alot is weighing on this.
option 1:
I can have my friend help get it to his house and we probably do the whole top end. He said we could check the barrings to see how they look. maybe do those....Don't know how much this be cuz we were gonna see whats good, whats bad and go from there. im guessing $800 to $1500 if just top end.
option 2:
Or my uncle knows a guy that will do the whole top and bottom end. Redo every seal and get the compression back up, maybe lose the flat head pistons and do a better performance one if this motor is compatible for it. $2700.
Mind you car has 126,000 miles on it. Main seals im sure need to be changed cuz there is some oil leaking somewhere.
SO which do you think? I dont really wanna spend close to 3 Grand, but if thats a really good deal for the whole engine let me know... never went through a process like this so im clueless on value for a job like this.
Old May 18, 2011 | 01:29 PM
first94's Avatar
first94
3rd Gear
Had my 94 two days. Got home last night and cranked her for a drive and saw tep gauge climbing fast. Had not seen this issue the day before. Shut it daow and traveled across town to pick up a thermostat, O&M 180 and put it in. Temp looked a lot better but then I noticed a fine spray and the water getting on the belt, could not determine where it is coming from. Shop today says replace the motor and something about a weep hole in the water pump.
After replacing the TS, temp never over 200 - 220. Any answers?
Old May 18, 2011 | 01:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
You have a bad water pump and they want to sell you a new motor?
IF you have bad head gasket you could be pumping exhaust gas through the cooling system which could blow the seals out but get that checked first.
Try a leadown test with the radiator cap off
