Lost
Old Aug 1, 2010 | 09:59 PM
marine69's Avatar
marine69
Cruising
Default Lost
I have a 1986 that absolutly does not want to start when cold. With a couple shots of starting fluid, it starts right up. Should I start with the cld start injector? The second half of this story is that when I turn the key to the on position, Sometimes I hear the fuel pump running and sometimes I dont?
Old Aug 2, 2010 | 08:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I would diagnose the fuel pump relay circuit. It sounds like you may be powering the fuel pump via the oil pressure switch. Here is some good reading, you will a PDF reader, such as Adobe.
http://members.shaw.ca/agent86/Fuel%...elivery-8A.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Fu...l%20System.pdf
Old Aug 2, 2010 | 08:55 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Be more specific on sometimes you hear the pump run. Do you hear the pump run the first time you turn the key on, or just sometimes?
Could be the circuit, could be the relay is going bad and could be in the pump itself. You'll have to do a complete pressure test of the fuel system to determine if it's fuel related.
And of course it could be the cold start injector. If it starts with ether it sounds more like a fuel delivery issue to me.
Old Aug 2, 2010 | 12:24 PM
Frizlefrak's Avatar
Frizlefrak
What Agent and Sarge said. Obviously a fuel delivery issue. Check relay first, then fuel pressure once relay is confirmed good. Let us know what you have.
Old Aug 2, 2010 | 01:20 PM
Bronze85's Avatar
Bronze85
No fuel pressure=no fuel=no start!
Old Aug 2, 2010 | 02:06 PM
redrose's Avatar
redrose
Originally Posted by marine69
does not want to start when cold. Sometimes I hear the fuel pump running and sometimes I dont?
had one just like that a couple of months ago...wiring harness connector inside the fuel tank ($12 at NAPA) was corroded, gray wire at the connector /pump looked as tho the plastic insulation had been stripped back a 1/4", melted from the resistance/heat where the plug sits on the pump...inside the connector was black on the pin for the gray wire.
check fuel pressure to see if this might be your doll's heart ache.
Old Aug 3, 2010 | 08:12 PM
marine69's Avatar
marine69
Cruising
Thanks for the ideas on where to start. I should have been clearer. when I turn the key on, i dont hear anything for the first few times I try to start it and then out of the blue, I hear the pump running.
Old Aug 4, 2010 | 08:33 AM
sailorsteve's Avatar
sailorsteve
When the pump runs, does the car start?
Old Aug 4, 2010 | 04:51 PM
marine69's Avatar
marine69
Cruising
No, I still have to spray it with starting fluid. After it starts, it runs great. I can take over countries with no problem but I am no mech. I know the components pretty good but dont know troubleshooting real well.
Old Aug 5, 2010 | 08:50 AM
AGENT 86's Avatar
AGENT 86
If you apply 12 volts to terminal "G" on the ALDL connector, do you hear the fuel pump run ?
Will it start with 12 volts on "G" ?
Old Aug 5, 2010 | 10:25 AM
Frizlefrak's Avatar
Frizlefrak
Do what Agent said first....
It sounds like your fuel pump relay has failed. In that case, the oil pressure switch should act as a backup and energize the pump once about 4 psi is reached during cranking....unless it has failed as well....or your car is taking a long time to build oil pressure for some reason during cranking. By spraying ether in the throttle body, you're able to start the engine, thus building oil pressure rapidly and closing the fuel pump circuit. My concern is why isn't this happening during cranking? Granted, it will take longer to start the car, but it should start. How many miles are on this engine, and how much oil pressure do you normally see at idle?
To Lost
