Reviving an Optima Red Top
During the winter it was in a warm basement and kept about 2 feet off the ground on a block of wood with a trickle charger. It failed to start the car in the spring without going on the real charger for an hour or so. The car that it is in sits around a lot in my garage - it is still on its first tank of gas for 2010. I drove it about 2 weeks ago and it started up just fine. Went to move it two nights ago and it barely had enough juice to click the starter solenoid. Registered 8v on my digital voltmeter. Not impressed! I've had plain jane lead acid batteries do much better and sit much longer than this Optima and crank right over when I need it. So can this be brought back to life? I put it on a 12v 2amp charge for a few hours last night but was leary to let it charge overnight in case it is damaged and shorts out. I put the trickle charger on it this morning before work. Is this nearly $200 battery junk? Having a tough time finding locally a sealed group 75 battery. This car has the battery trunk mounted so no fumes is important. Would also like to find a sealed battery for the Vette to replace the leaky ac delco in there now.
drop the Optima in the nearest waste receptacle (actually please recycle). pony up for a Sears Platinum plus or an Odyssey.
In the past 10 years I have had to replace an Optima 3 times in one car (warranty or it would have been gone the first time). I have a Platinum plus in both my others and not one failure in the same time frame. I know others with Odyssey's that are running strong as well.
Yes I am rough on Batteries.
sears platinum:
Power Ratings:
Cold Cranking Amps (CCA at 0 deg.F): 880
Reserve Capacity (RC): 135 min.
Amp Hours at 20 Hour Rate: 68
Odyssey
MODEL Voltage
34-PC1500 12
CCA 880
Reserve Capacity minutes 135
Optima
12v
Cold Cranking Amps @ 0F 800
Cranking Amps @ 32F 1000
Reserve Capacity 100
Capacity (C/20 Rate) 50
Internal Resistance (ohms) 0.003
you do the math...
Maybe it will help you.
"Once a batteries voltage falls below a certain level, the charger can no longer sense the battery's presence and will refuse to deliver the current. In some cases this can occur at any point below 10.5 volts." They recommend connecting a decently charged battery in parallel with the problem battery and then charge normally. This is from Sept. Hot Rod magazine. Also, sealed is something of a misnomer--lead-acid batteries are generally capable of venting when necessary.
In your case, you could consider rear mounting a conventional battery in a sealed case that is vented to the atmosphere and not the inside of the car. I understand why the Optima was selected....I'm just not a fan of their reliability, or lack thereof.
(almost)My .03 is to Pony up for an Interstate...
Optima batteries are garbage. I went through 4 of them in a 3 year span between 2 Corvettes. Since I switched to Interstate not a single problem. I have a Sears battery in my old Yukon for 4 years with no issues as well. No experience with Odyssey but I've heard they are similar to Optima in that people either love them or hate them.
A friend of mine who has been a high end mechanic and racer for 30+ years was looking at my '96 when I got it. I kid you not, the first thing out of his mouth was "Nice car other than that piece of **** battery (Optima)"
You cannot do any harm to a lead acid battery by storing it on ANY normal surface!!!!!! This old tale just will not die a natural death. You do not have to support the battery with insulators, wooden strips, or pay someone to hold the battery off the floor during storage.
My battery sits and gets low, I put a charger on it.
I have a garden tractor with a 12 year old battery in it, that dies over every winter; then I charge it in spring. (that is my record for a battery KNOCK ON WOOD)
This is the best charger I ever had.
http://battery-rechargeable-charger....y-charger.html
Not all chargers are created equal either. Traditional "float" chargers provide a constant voltage with tapering amperage to the battery, even when it is fully-charged. These are OK, but not preferred. For float charging, we recommend 1 amp max, 13.2-13.8 volts. For regular charging, we recommend 10 amps max, 13.8-15 volts. Generally speaking, fully-automatic "multi-stage or multi-step" chargers, which monitor the battery and charge it as necessary, are the preferred option. Multi-stage maintainers will charge at varying voltages and varying amperage (rarely exceeding 2 amps) and some of these multi-step chargers are also capable of being regular battery chargers (7 amps or more).
The key to long battery life (regardless of brand), is to always maintain at least 12.4 volts whenever possible. When batteries are allowed to discharge below that level and sit for extended periods of time, sulfation begins to diminish both performance and lifespan. Maintaining a battery properly during winter storage is often only half the battle. If a vehicle sits for extended periods of time during the summer, it’s also a good idea to keep the battery maintained. As cuisinartvette noted, this is especially true on newer vehicles, where more complex electrical systems create a higher parasitic draw on batteries and can discharge them at an even faster rate.
I know many of you have watched this video before, but I do like pointing out the battery tenders and maintainers used in this collection. Even people who can afford to buy a new battery every weekend would rather properly-maintain the ones they already have- http://www.youtube.com/watch?v=eMQMgwouKlU
Goldcylon offers excellent advice about checking for a parasitic draw or loose cables. The typical key-off load for most vehicles is about 25 milliamps, but vehicles that have significantly higher key-off loads can completely discharge any battery within a matter of weeks or even days.
The article Joe B. and powerpigz-51 cited and the YouTube link nassau66427 posted are both excellent resources for learning how to recharge deeply-discharged batteries. If batteries are deeply-discharged, many chargers will not recognize or charge the battery. This is a charger issue and is not unique to Optima. In fact, other manufacturers have dealt with this situation by voiding the warranty on any returned battery that has been discharged below 10 volts. We decided to make the YouTube video instead, which explains how to properly recharge these batteries.
Fully-charged, RedTops will measure approximately 12.6-12.8 volts. Batteries that measure 8 volts are often severely discharged (and sulfated), but they could also have other issues associated with them. If you are recharging your battery with low amperage, it is not uncommon at all for a battery to take several hours to go from 8 volts to 11.9 volts. An easy way to think of it is that the rated capacity of a battery (Ah) is the size of the battery’s tank for storing electrical power. If a battery’s Ah rating is 50 amps and it is completely discharged and being charged at a 2 amp rate, theoretically it will take 25 hours (50/2) for the battery to get fully-charged. This assumes 100% efficiency in the charging process, but most battery chargers do not provide a constant current through the charging process, with the current tapering off early in the process.
If anyone has any questions about our batteries, I’ll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
Jim McIlvaine
