Thanks for the input. Any idea how long the pulsators last and what fails? Its not like they are cheap anymore either, $15 now. The hose is way cheaper and if it works, even better.
you should be OK for some time. It's not like it's going to fail in the next year. If it does, it's a fluke. but if you ever have a leak down that's the first place I'ld start if your tests determine it's a pump.
I will pull the hose off tonight and see what it says.
If you're talking about the FPR. Pull the hose off. The pressure should jump up to well over 40, or at least over your normal reading. If gas starts flowing out of the line your FPR is bad. That happened to me so be ready with a towel to catch any fuel spillage. Actually have the rag wrapped oround the area so noe gets spilled if this happens. If any fuel comes pooring out change the FPR. You can also tape the gauge to your windshield and go for a drive and monitor what the pressure does.
Also before you start take the line off and inspect it to see if there is any fuel present or the smell of fuel.
Lesson learned on this one. If the problem comes up again, I will replace the pulsator with a piece of hose.
When I tested it a few weeks ago, it tested out fine, no fuel in the hose, but I want to definitely see what's going now with a working fuel pump so I will retest. I need to replace the FPR anyway to get the pressure up to 36psi according to Jon at FIC to correctly match the injectors I have.
I thought 32 sounded kinda low. Mine, when everything is working properly goes to 42. I don't know if there's a difference for the years though. IIRC I think there is.
From what I know for the 85, its within spec. The 85 had different injectors from the other years and did not require high fuel pressure. With the Bosch III's that I am currently running, to best atomize the fuel, I need to up the pressure to 36psi, vacuum hose connected, at idle.
I spoke to Jon at FIC today and he said I can leave it the way it is if its running right or replace the FPR with an adjustable one to boost the pressure. He also suggested removing the vacuum hose to see if the pressure goes up. If it does, then he said I can run without it connected. I'm thinking of installing an AFPR anyway so a call to TPiS is in order.
I will print a copy of this in case I need it for the future. I always thought like most cars the tank had to be dropped. Hey the boys at Chevy made one thing eaiser than most cars to repair on the Corvette.
I used those instructions to help me in my little project. I was worried about breaking the tabs off the sending unit, so I acquired a spare. I wound up breaking a tab on the spare, wouldn't you know it. But I put a clamp on it and it holds and doesn't bind the float, it travels freely. Its in my storage cabinet with other C4 parts, just in case. I used my original unit and it cleaned up nice, the gauge works.
I got a chance to check the FPR tonight. Ignition on, pump primed, pressure is 42psi or there abouts and then falls a little. Engine on, with the vacuum hose on, 32psi at idle. With the hose off, 42psi at idle. There was no gas in the line either. I feel better now that I know its working and I don't feel rushed to get me an AFPR.
How did that confirm that the AFPR is working? All it says is that it maintains pressure faster than it bleeds off. I though you have to maintain pressure after shutdown for a bit? If it doesn't then either it is leaking at the injectors or at the FPR?
True for Budweiser. Drinking Fat Tire, by step (and beer) 4, I'd have mounted the fuel pump in the windshield washer tank and be wiring it to the horn switch
"I'd have mounted the fuel pump" Thought that was going in a different direction. Dam Friz, you'v got a lot of stars!
