Replacing Fuel Pump
Old Aug 7, 2010 | 02:23 AM
Jonathon1990vette's Avatar
Jonathon1990vette
Default Replacing Fuel Pump
Does anyone know or have the steps to replacing a fuel pump? And how difficult would it be?
Thanks in advance!
Old Aug 7, 2010 | 02:30 AM
Frizlefrak's Avatar
Frizlefrak
Falling off a log easy. Less than a 30 minute job the first time you do it. '
1. Remove the fuel door.
2. Remove the rubber boot.
3. Disconnect the harness
4. Remove the fuel pump assembly bolts
5. Carefully lift the assembly out of the fuel tank, and tape up the opening to keep fumes out of your garage.
6. Remove the pump from the sending unit, and install the new pump. Replace pulsator hose (many use fuel injection line) and filter sock.
Reverse steps 1-5
You won't even finish the second beer
Old Aug 7, 2010 | 03:00 AM
Pwnage1337's Avatar
Pwnage1337
Did this about a week ago and it is very easy. I have read about the fuel pump assembly mounting bolts breaking off in the gas tank but I didn't experience that.
My new pump is so quiet I can't even hear it when it primes the fuel rail. The old one I could hear very distinctly.
Old Aug 7, 2010 | 03:15 AM
rodj's Avatar
rodj
Like this guy wrote with pictures?
http://forums.corvetteforum.com/c4-t...h-article.html
Old Aug 7, 2010 | 03:52 AM
Jonathon1990vette
Thanks for the quick replies guys! It would be tomorrows project.
Thanks again!
Old Aug 7, 2010 | 04:38 AM
Joe C's Avatar
Joe C
Reverse steps 1-5
Originally Posted by rodj
great write-up Frizlefrak - . the fuel pump is one thing i've never done. i did have a pump failure in my 85 years ago, but i was about 100 miles from home, and at the mercy of a local dealer. ended up paying $286 (parts and labor). didn't think that was too bad considering the circumstances. i have filed your article in my tech library, and hopefully some day i WON'T have to use it - . again, thanks for taking the time to write and photograph the procedure.
Old Aug 7, 2010 | 07:20 AM
Paul Workman's Avatar
Paul Workman
Just to add...
If you have those plastic ratchet-type hose clamps on your pump, don't try to reuse them. Pitch 'em and go with the worm gear hose clamps.
Speaking of bolts breaking off (unlikely) when I did the pumps (yes two on a Z) I found a friggin red shop towel floating around in the tank. Something tells me it wasn't the first rodeo for the fuel pumps on my beloved ZR-1!
Good ol ACE Hardware had stainless bolts to replace the originals. You'll likely have to do a bit of cleanup around the gasket area - or at least I did (rust, ya know). BUT! you don't want to use steel wool or ANY frigging thing that might cause a spark...if you know what I mean. I used a bead of Permatex instead of a gasket. Works well!
P.
Old Aug 7, 2010 | 11:51 AM
Frizlefrak's Avatar
Frizlefrak
I don't know if I would trust that dude or not....looks like he's snickering about something in his avatar.
Old Aug 7, 2010 | 03:11 PM
aklim's Avatar
aklim
Reverse steps 1-5
Utter BS.
Step 1, Beer
Step 2, Beer
Step 3, Beer
Step 4, Beer,
Step 5, Beer
Step 6, Beer
6 beers right there. Then one to celebrate, 6 more to reinstall, 1 more to celebrate. Test takes 1 more beer and 1 more to celebrate. 10 beer job.
Old Aug 7, 2010 | 04:32 PM
Frizlefrak's Avatar
Frizlefrak
True for Budweiser. Drinking Fat Tire, by step (and beer) 4, I'd have mounted the fuel pump in the windshield washer tank and be wiring it to the horn switch
Old Aug 7, 2010 | 04:50 PM
aklim's Avatar
aklim
Pour gas into the windshield washer tank and keep the finger on the horn. If you need to use the horn, flash the sign "Horn Broken. Watch for Finger".
Old Aug 7, 2010 | 05:10 PM
dfalliaux's Avatar
dfalliaux
St. Jude Donor '08-'09-'10-'11-'12-'13-'15
Originally Posted by aklim
Utter BS.
Step 1, Beer
Step 2, Beer
Step 3, Beer
Step 4, Beer,
Step 5, Beer
Step 6, Beer
Old Aug 9, 2010 | 05:21 PM
gabezC4's Avatar
gabezC4
Default Horror Story
Had a repair shop tell me mine would take 3+ hours to do that on my 1988. He then came back and said he made a mistake and that it is only 1 hour in the labor guide. $160/ hour labor with parts and I felt like I had be raped for just a little ole fuel pump.
I fill up with gas whenever the read out is 1/4 full just so I don't have to get another pump soon!
Old Aug 9, 2010 | 05:34 PM
aklim's Avatar
aklim
1 hr isn't bad. Takes me about that long.
Why? What has one got to do with the other? Surely you don't believe the old wives tale of fuel cooling the pump.
Old Aug 11, 2010 | 02:55 PM
ejscarfo's Avatar
ejscarfo
This is my project for tonight. I have a new fuel pump and pulsator ready to be installed into my 85 and hopefully it doesn't turn into a major project. I will clean the sending unit when I have it out as well, my gauge reads full until its about 2/3 empty, then it starts to work. I have a new gasket and plan to use the original bolts. Is there anything I need to do with the old bolts, i.e. sealant on the threads, etc?
Old Aug 11, 2010 | 03:54 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
I never put any sealant on mine. Clean the old bolts if you don't have new ones.
IF you have a pulsator you can use it but it's best to replace it with a piece of fuel injection hose. Do not use just any old rubber hose.
I saw your thread on this as well but I don't know about the particular pump you're putting in. I would think they should all be pretty similar though.
Old Aug 11, 2010 | 04:19 PM
ejscarfo's Avatar
ejscarfo
Thanks for the input. Any idea how long the pulsators last and what fails? Its not like they are cheap anymore either, $15 now. The hose is way cheaper and if it works, even better.
To Replacing Fuel Pump
Old Aug 12, 2010 | 01:54 PM
aklim's Avatar
aklim
If it is that double hump thing between the metal fuel line and the pump, I would dump it. Actually, I DID dump it. When it gets old, it can leak fuel so why bother?
progress updates?
Old Aug 12, 2010 | 02:11 PM
ejscarfo's Avatar
ejscarfo
progress updates?
That's the thing. Its installed, I did it last night. New Facet-Purolator pump, OEM strainer and Motormite pulsator. I fixed the gas gauge as well. Its holding pressure, finally. It idles at 32psi and this morning, after sitting for 9 hrs (I left the gauge on to check it), it only bled down to 20psi. Before, with the old assembly, it would bleed down to 10psi in 5 minutes. Didn't get a chance to road test it, but it idles fine and seems smooth when I rev the engine, no hesitation.
Now for a new FRP. Better get more beer.
Old Aug 12, 2010 | 02:27 PM
aklim's Avatar
aklim
I'm not sure that is right. Only way I know of to test it is to see what pressure it runs with the hose off.
