I just installed my new Alternator and its not charging at all, i would assume maybe a bad alternator but while installing the plug wire underneath the alternator got a little messed up could that plug wire cause it not to charge the batt?
Also its a 1993 Corvette!
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Well i forgot the wire was there when i original pulled it out and some of the plug was a little cracked and one of the pins on the plug wire was a little bent i tried to put it back the best i could.
