digital dash help
Old Aug 20, 2010 | 10:09 AM
chrisreynolds's Avatar
chrisreynolds
8th Gear
Default digital dash help
i have tried everything to fix my digital dash in my 86 i have went to batee.com followed there instructions i have taken a working dash out of another corvette and i didnt work right now my dash rarely comes on and if i comes on it only stays on for about two minutes and the lights scrabble around a lot on the screen or it will just be frozen on the screen with every light light up i have the shop manual for my year and have tried following wires with no luck i have tested all the wires at the connector to the dash and all the powers and grounds have 12v except for one of the grounds had about 6v so i tried finding out why that might be and had no luck plz help
Old Aug 21, 2010 | 12:40 AM
Jay Axson's Avatar
Jay Axson
Does the old instrument cluster and the new one have the same problems? Do you know for sure the new one worked? If their behavior is the same my trouble shooting instinct would to be put the old dash in another of the same generation car and see if it works ok. But this is highly inpractical considering so I would start looking upstream.
Good luck, electronic grimlens can be a real PITA sometimes.
Old Aug 21, 2010 | 01:24 AM
yaknow's Avatar
yaknow
highly unlikely both dash clusters would have the same problem. Let me start out I'm lousy with automotive electronics, took me 2 evenings to convert
Old Aug 21, 2010 | 02:03 AM
jfb's Avatar
jfb
If both clusters do the same thing, the problem isn't in the cluster, it is in the connections to the cluster. No wire going to ground should have 6 volts on it, it should be zero volts! With the ign off, you should see zero ohms on the ground pins on the connectors with an ohmeter. If not, trace the ground wire and find out why it doesn't go to ground.
Old Aug 21, 2010 | 03:53 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You say ALL the powered wires & grounds have 12 volts except one that is 6 volts. There should be power ONLY at the power wires, grounds should have NOTHING.
Old Aug 21, 2010 | 04:27 AM
powerpigz-51's Avatar
powerpigz-51
Did you resolder the joints to the pin connector that joins the 2 boards together? I would say that if it works occasionally that you have a bad connection.
Old Aug 21, 2010 | 08:31 AM
megtom2's Avatar
megtom2
I also have an 86 with a crazy dash. The dash itself is fine. Our problem is in the wiring. I have ran a ground wire directly from the battery and connected it to all three ground wires but the dash still does exactly what you just described. It works more than it doesn't so I guess we will just live with it.
It does seem to do it more when it is hot outside. Most of these electrical gremlins seem to pop up when it is hot outside.
Old Aug 21, 2010 | 02:31 PM
powerpigz-51
Did you resolder the pin joints between the 2 boards?
Old Aug 21, 2010 | 04:07 PM
megtom2's Avatar
megtom2
I have looked over the boards with a magnifying glass and every solder point looks good. When it does go out all I have to do is push in at a certain point by the speedomoter and it comes back up.
Old Aug 21, 2010 | 05:31 PM
powerpigz-51
You may not be able to see the cracks. I am referring specifically to the joints on the pins and the female connector on the other board. You may hit the joints with a soldering iron and add a small amount of new solder, this is easily done and may fix your problem.
Old Aug 21, 2010 | 10:37 PM
chrisreynolds
8th Gear
hold on a sec so your saying if i touch an ohm tester to the positive on my battery and i stick it to the grounds in the connector it should read 0 volts because they read 0s when you touch negative to the grounds but i thought when you touch positive to the grounds it should come up 12v am i right or are they suppose to be 0s
anyways my dash works in the same model corvettes i have tried it someone has had to have had a perfectly good dash before and cant get it to work in there car anyone?????
Old Aug 22, 2010 | 12:23 AM
jfb's Avatar
jfb
You connect the negative test lead of a voltmeter to ground (or the battery negative terminal) and the positive test lead to each ground wire on the sockets the cluster plugs into and you should read zero volts showing that the grounds actually make connection to ground.
If your cluster also doesn't work in someone elses same year Corvette, then you have a cluster problem and you should have one of the repair stations fix it.
Old Aug 22, 2010 | 09:58 PM
HlhnEast's Avatar
HlhnEast
Youve been Batee'd
http://www.batee.com/corvette/dcrg/index.shtml
Great site, check it out
Old Aug 23, 2010 | 12:26 AM
chrisreynolds
8th Gear
no my cluster does work in other corvettes its not the dash and batee.com is no help because that only helps you fix it if its the dash mines either the connectors or prolly some ground wire but i think the grounds are good
Old Aug 23, 2010 | 09:44 AM
HlhnEast's Avatar
HlhnEast
Batee has wiring diagrams to help diagnose the connectors as well as shows you which pins are grounds. It also shows voltages of each to check. Pretty labor intensive but the info is there. Run temporary ground wires and connect at the right points to check them. I have a ground issue but have been too lazy at this point to correct it.
To digital dash help
