removing rear hatch struts
Location: The reason time exists is so everything doesn't happen at once
I need to remover the rear hatch struts in order to install new weather stripping. What is the best way to do this; from the top (glass end) or the bottem?
thanks
thanks
Make sure you support the glass adequately....that puppy is HEAVY. Doesn't matter top or bottom first....compress the clip, and off she comes. Takes about 15 seconds per side.
I asked wife to hold it up for me.( big mistake) I took 2 two by fours and put rags on them to hold it up till I got weather stripping thru the struts
