problems with msd coil?
Old Sep 3, 2010 | 06:13 PM
littlesk8cracker's Avatar
littlesk8cracker
Default problems with msd coil?
so i have an msd coil for my 94 lt1, havnt installed it yet. i did a search an couldnt find much info, but i saw a few people who have had trouble with them. so is it worth it to put it in or should i just try to return in? is there any way i can open it and check to see if its good, or is it something thats gonna go bad after driving for a little bit? thanks!
Old Sep 3, 2010 | 06:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Dont take it apart...Used one on an 89 and worked the same as stock. Did make the tach go wacky which for some reason seems common so I put the stock one back on. As far as did it work well yes.
Unless your car is highly modded you really dont need anything more than stock ignition parts.
Old Sep 3, 2010 | 07:04 PM
RedLS1GTO's Avatar
RedLS1GTO
Old Sep 3, 2010 | 11:25 PM
STL94LT1's Avatar
STL94LT1
I've been running an MSD coil on my 94 for ~4 years without a problem.
To problems with msd coil?
