Thinking about saving a C4
Old Oct 23, 2010 | 08:31 PM
  #141
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Any updates?
Old Oct 23, 2010 | 10:07 PM
  #142
Piper250's Avatar
Piper250
Yeah - whatz happening ?
Old Jun 30, 2011 | 09:58 PM
  #143
TGTINT's Avatar
TGTINT
June Update.
*I posted an update thread a while back but I'm not sure who caught it. I should have kept it all here.
So a fall update would be. rebuilt motor, refreshed the heads and did just about everything including a new cam. The motor had a bad head gasket and worn rockers.
Then I hit the paint!
We scored some nice C5 wheels with fresh rubber for next to nothing.
Then we did a brake upgrade. Had to paint em red!
Next is tint, more cleaning and a new drivers side power window motor. The new weatherstripping did a number on the motor. I have some ASR codes and engine light. Dad should be visiting soon again so we will work on that soon.
Old Jun 30, 2011 | 10:29 PM
  #144
atgordon's Avatar
atgordon
Tim is right in that we did work on the car ... but he skimped a little on the detail. Compcams roller rocker special (to go with the new RR's). All non-rotating internal/external engine parts renewed. New oil pump. New Water pump. New Optispark. New coil pack. New water hoses.
The C5 upgrade was straight from the list postings and used Jeffvette brackets (worked like a dream!), and searching down the GM part numbers we ended up with a really low cost upgrade (I think the C5 calipers are GM units from Australia, via Google. Way cheaper than dealer or Vette-dealer sourced items).
The interior needs some finishing off, but the car drives just as it should! I'm really looking forward to bringing her home to Michigan in September. I just hope that my TR6 rebuild is far enough forward by then that the Vette can share garage space!
Old Jul 1, 2011 | 03:31 AM
  #145
USAFPILOT's Avatar
USAFPILOT
Stumbled across this thread today...how sweet it is.
Old Jul 1, 2011 | 11:46 AM
  #146
F22's Avatar
F22
I remember this thread and thanks for updating it again! Very, very cool! You and your Dad did a great job on saving this C4! I am sure, that your C4 is returning the love you put into it!
Old Jul 1, 2011 | 03:51 PM
  #147
Richard Church's Avatar
Richard Church
Love the color, hate the snakes. It's a keeper.
Old Jul 1, 2011 | 04:29 PM
  #148
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Wow, great thread! Great job saving her!
Old Jul 1, 2011 | 06:07 PM
  #149
Frizlefrak's Avatar
Frizlefrak
I remember it too. Thanks for the update.
Old Jul 1, 2011 | 06:34 PM
  #150
F22's Avatar
F22
From this: sitting in somebody's backyard, rotting away...
To this: waiting to pounce on something on the street!
I'm impressed! Great job evaluating, repairing and saving this C4!
Old Jul 1, 2011 | 10:03 PM
  #151
mtwoolford's Avatar
mtwoolford
Originally Posted by TGTINT
June Update.
you pulled the engine with bell housing and flywheel from the side ?
Was the clutch still attached to the flywheel ?
Did you leave the transmission in place ? If so, any problems clearing the transmission input shaft ?
gotta do mine; wish I had an as enthusiastic helper.
Old Jul 1, 2011 | 10:04 PM
  #152
ZR_Don's Avatar
ZR_Don
CI 2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '06
This is Much better then Cable News...................
Old Jul 1, 2011 | 11:30 PM
  #153
TGTINT's Avatar
TGTINT
We yanked the trans from below. Its a heavy bastard. Yes the clutch and flywheel were still attached inside the bellhousing.
The motor pulled from the side, it was tight but it was actually very straight forward. The only challenge was the car was high on the HD jackstands we really had to get the motor high to pull it out.
Dad def got his use out of me, we did the entire pull and rebuild in 7 days.
Old Jul 2, 2011 | 12:26 AM
  #154
mtwoolford's Avatar
mtwoolford
even God rested on the seventh day
Old Jul 2, 2011 | 12:53 PM
  #155
screamin_conure's Avatar
screamin_conure
WOW! This is what it's all about! You guys should be proud of yourselves!
I almost got a little choked up when I saw the before/after pictures. Very, very nice!
Old Jul 2, 2011 | 04:49 PM
  #156
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Wow! Impressed, amazed, speechless. And that takes a lot!
Old Jul 29, 2011 | 06:34 PM
  #157
TGTINT's Avatar
TGTINT
*July 29th Update*
Dad is back in San Diego and we are working on the window motor / AC / driveability issues.
The project started out mellow, the window motor was not busted the window switch had got a little funky from removal and had to be pushed back in place to allow continuity so the motor would work.
Next was new emblems... yeah removing those didn't go too well but I'll keep you updated.
She is down at the AC shop getting recharged, hopefully this will stop the fan from running non stop and assist us with some codes.
Sorry for the quick post, more to come!
To Thinking about saving a C4
Old Jul 29, 2011 | 09:28 PM
  #158
atgordon's Avatar
atgordon
Tim (TGTint) forgot to mention that once the engine was out, the entire tear down and rebuild was done by me while Tim was at work! Took five days, including have the heads pressure tested and valves seated and installed. I replaced every part apart from the major rotating assembly! (oil pump, water pump, Opti, coil, EGR, all sensors, etc.
I should finish by readily admitting that he really pulled his weight on the pull out and reinstall, and most evenings as well!
It's great to be now fixing the small items and trying to determine why we have a very persistent ASR light on ...
More next week before I return to Michigan once more ...
Tony (Tim's Dad)
Old Jul 29, 2011 | 10:18 PM
  #159
Vette Daddy's Avatar
Vette Daddy
Super neat stuff!
Old Jul 29, 2011 | 10:36 PM
  #160
yakmastermax's Avatar
yakmastermax
so jealous wish my dad worked with me!
