Thinking about saving a C4
Old Sep 14, 2010 | 12:02 AM
TGTINT's Avatar
TGTINT
Default Thinking about saving a C4
Howdy all,
I'm marinating on saving a C4 that's been sitting for almost two years in a field under a cover
Not really worried about "what its worth" I'll make my offer and be content with what happens.
I'm more curious on what things are notorious for going bad after sitting that long. Its a 94' LT1 6 speed coupe that needs a new clutch installed. This car has an interesting story behind it, kinda sad. This was obviously someones baby.. master mechanic, took care of the car planned a repair, he removed the serp belt and mass air with plans to replace the clutch and fell ill and passed away. His kids parked it not sure what to do and now they need to sell it so I'm here. Only bummer is regardless of how nice he treated it, the poor car has been subjected to no love for two years.
Always been a Mustang guy but my Dad wants this exact car and I can get it up and running for him. That and it sure would be nice to honor the previous owner and get his baby back in tip top shape. I'm a sucker for a car guy story though....
Thanks for any support
Old Sep 14, 2010 | 12:37 AM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
it is a sad story, but you can make it a happy one for your dad and maybe that mans kids by getting that car back to the way it should be. sound like a great idea to me. good luck keep us posted
Old Sep 14, 2010 | 12:40 AM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Gas turns to shellac. Brake fluid turns to sugar. Mice and other rhodents chew on wiring and establish small colonies, mold can grow inside the cabin, rotors can become bonded to brake pads, oil can turn to sludge. The list can go on and on.
The bright side, if none of the 4 legged creatures have taken up housekeeping or practiced "carry out" on the electrical components or seating, the mechanical problems are minimal, nothing a few thousand as in 3,4,5 and maybe even 6 couldn't correct.
Begin with full flush of the dexcool out of the block and radiator it's probably turned to jello by now. remove motor and trans from it's resting place, disassemble motor, to make certain pistons, rod bearings and crank bearings are not siezed. replace all gaskets from oil pan up flush out fuel system, flush out brake system, replace all broken and dried up vacuum hoses, coolant hoses,probably needs a new heater core and replace that serpentine belt. New battery, new tires.
This is just the beginning of a rather long list. Are you up for it ?
Old Sep 14, 2010 | 12:56 AM
TGTINT's Avatar
TGTINT
I've started motors that have sat longer than two years without tearing down!
I'm not new to resurrecting vehicles but I'm not after that big a project either. My plans were clean, flush, turn over, start. Oil looks fantastic, def 100% with you on brakes, coolant, etc...
Def had some critters, mostly spiders everywhere but I'm pulling it further out to inspect. Grass was short around it but that means nothing.
Old Sep 14, 2010 | 03:17 AM
mcm95403's Avatar
mcm95403
My 69 Road Runner sat in the previous owners front yard for 10 or 11 years - he couldn't remember the year he parked it. I put a battery in it and it started up on the old gas, points, plugs and everything. That car ran great, no tear-down required - even beat a small-block Pinto from a stand still.
If you don't see any obvious damage, I say go for it.
Old Sep 14, 2010 | 06:38 AM
78pacer's Avatar
78pacer
It's only rwo years, not twenty two. I agree on the critters dining on the plastics and foam etc, but the car should be able to move and be flatbedded to its new home for further inspection. If the vette can be purchased cheaply enough, go for it!
Mike
Old Sep 14, 2010 | 07:55 AM
jmgtp's Avatar
jmgtp
Keep in mind that the steel stuff, like brake rotors, are probably rusted solid to the calipers by now from sitting in a field. Moisture damage and rodents doing some rewiring would be my worry. Oh and spiders.
Old Sep 14, 2010 | 08:57 AM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
It's a crap shoot. You could come up a winner...... Or you could come up a loser. Are you a gamblin man?
Old Sep 14, 2010 | 10:09 AM
Muffin's Avatar
Muffin
I think you are on the right track. Though long two years is not an eternity. If the wiring hasn't been eaten the remainder should be fixable with some serious TLC.
Old Sep 14, 2010 | 10:34 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Two years is really nothing. I'd be more worried about transmission problems. Present condition and price would be the biggest concerns. Paint and interior is a lot more expensive than mechanicals (outside of the transmission).
Old Sep 14, 2010 | 10:41 AM
TGTINT's Avatar
TGTINT
I sure am... that and I have a weird impulse for buying strange cars I've wanted to own. I just feel bad because I've gotta break it to the guys daughter this car isn't worth near what she expects. She isn't aware of what storing a vehicle like this does to it.
Thankfully arachnophobia isn't an issue because thats what took residence in the car. She is a sweet car, diamond in the rough for sure but a LOT of work will be needed. Once I know if its a go I'll share more details.
Old Sep 14, 2010 | 11:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
Just work on it some, most that have a Vette think its special or made of gold just ignorance thats all.
If the price is right go for it.
Old Sep 14, 2010 | 11:04 AM
corvettemaster's Avatar
corvettemaster
Mike
And if only the MAF and belt are currently removed, I'd throw them back on along with a charged battery to just see how the motor sounds. Plus make sure all the electronics work and rodents didn't get to them. You never know, might have been more than just the clutch needing replaced and his kids didn't know all the details. Do you know how many miles it has on it?
Be sure to let us know what you decide. Good luck.
Old Sep 14, 2010 | 11:09 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Isn't that what we all do?
2 years? Go for it. If I had the time and extra cash laying around I wouldn't hesitate.
Old Sep 14, 2010 | 11:31 AM
TGTINT's Avatar
TGTINT
I need to get some juice to this car to check mileage. Although I'm sure ya'll will agree its kinda a moot point since the sitting kills it. Just don't wanna tell the family is has 80k on it and they think its worth more even though the same work is needed.
In the rear hatch there is an AC Delco clutch, new plugs, and serp belt. So it seems he had everything ready to go on some repairs.
Just gotta worry about those critters, and the mystery issues
Old Sep 14, 2010 | 11:32 AM
Redghost's Avatar
Redghost
St. Jude Donor '10
I purchased a 1973 Chevy pick-up, in 1984. It had been sitting for 4 years out in the California desert, (outside of Barstow). I had to "pour" the sand out of the air cleaner, plus drain, flush and replace all fluids and etc.. The truck had 96K miles on it, at the time, and now has well over 750K on it, and still running. It is my "secondary truck" but I just can't part with it. It has been with me too long. It is a good example of "American Iron".
This is a good luck story. There are stories out there with a lot different endings. Just use "good common sence". You should be OK
Thanks for "saving a C4".
Old Sep 14, 2010 | 11:45 AM
TGTINT's Avatar
TGTINT
couple teasers
To Thinking about saving a C4
Old Sep 14, 2010 | 11:59 AM
84drb's Avatar
84drb
Wow, the inside looks like its in great shape! Id like to guess the body will clean up just as nice. Might be able to get a nice deal here!
Old Sep 14, 2010 | 01:01 PM
RetiredSFC 97
after seeing the pic, I say yes it's worth a second chance
Old Sep 14, 2010 | 01:06 PM
dukeallen's Avatar
dukeallen
That interior looks better than mine!
