Start problem
Old Sep 28, 2010 | 10:36 PM
aerospace31's Avatar
aerospace31
1st Gear
Default Start problem
Parked the vette in the garage and then came out later to start the car to leave, turned the key all the way over and there was no starter ingaugement. It acted as if the car was not in park. Turn the key off and tried again and same thing. Move the gear shift to neutral and still would not turn over. All lights on the dash come on, battery has full charge. Even moved the car and heard the trans lock in gear after putting gear shift in park. Need advise. Thanks
Old Sep 28, 2010 | 11:43 PM
derekguzz's Avatar
derekguzz
Had simliar problems. Check your ICM. Small almost computer chip above the Coil with a wire and connector going to it.
Old Sep 29, 2010 | 12:10 AM
jfb's Avatar
jfb
Most likely VATS. I'm going to turn in. Tomorrow I'll post how to test your VATS.
Old Sep 29, 2010 | 09:12 PM
ezspdr's Avatar
ezspdr
I agree, had the same problem.
Old Sep 29, 2010 | 10:40 PM
rodj's Avatar
rodj
Most likely VATS.
http://www.joestradingpost.com/vats/
http://forum.grumpysperformance.com/...lit=vats#p3403
http://www.thirdgen.org/vats_passkey_system
To Start problem
