Fuel Filter
Old Apr 1, 2002 | 10:15 AM
Jim D's Avatar
Jim D
Default Fuel Filter
Are there O rings that go in the fuel filter be installing , are they GM or can I get them at any auto store tahnks Jim.
Old Apr 1, 2002 | 11:31 AM
chucks00's Avatar
chucks00
Cruise-In III & VI Veteran
Default Re: Fuel Filter (Jim D)
On my 87 no O rings are used. You are talking about the main Fuel filter behind the front wheel right?
Old Apr 1, 2002 | 11:41 AM
Jim D's Avatar
Jim D
Default Re: Fuel Filter (Chucks87)
yes thats the one I'm talking about , I read on the forum that you should put new gaskets omn when installing the filter. I assumed they were o rings, but could be wrong.
Old Apr 1, 2002 | 12:12 PM
FSTRNU's Avatar
FSTRNU
There arent any on a 93
Old Apr 1, 2002 | 12:16 PM
JonM's Avatar
JonM
If it needs new O rings...they will be in the box
Old Apr 1, 2002 | 01:00 PM
Jim D's Avatar
Jim D
Default Re: Fuel Filter (93Zeus)
Now I'm confused, I just spoke to Jeff Koop and he gave me the part# for o rings.
Old Apr 1, 2002 | 01:09 PM
vettenuts's Avatar
vettenuts
Yes, it does indeed take o-rings. The o-rings generally stay on the pipes and you can't see them very well unless you look very closely (not easy with fuel dripping out). If you change them, check the ends of the tubes for burrs prior to removal of the old ones. Lube the new ones with lots of oil prior to installing on the ends of the tubing.
Old Apr 1, 2002 | 04:29 PM
92BAV's Avatar
92BAV
Yes, there are O-rings, as previously mentioned. My Chevy parts guy just threw them in for free when I bought the filter.
Old Apr 1, 2002 | 04:45 PM
chucks00's Avatar
chucks00
Learn something new everyday. :crazy:
Old Apr 1, 2002 | 04:52 PM
carter200's Avatar
carter200
Default Re: Fuel Filter (92BAV)
Yep, o-rings :yesnod:
Old Apr 1, 2002 | 05:59 PM
Sharky Guam's Avatar
Sharky Guam
Default Re: Fuel Filter (carter200)
When you install the new filter, try not to spin the filter as you are tightening it. Put one wrench on the fitting and another on the hex on the filter housing. Preventing the filter from spinning will ensure that the orings are not damaged. A damaged oring may leak either right away or possibly after some vibration. I would hate to see a vette burn to the ground because of an improperly installed filter. It has happened.
I forgot to add that I use a dab of grease on the fittings instead of oil. The grease, used sparingly, helps the oring to properly seat.The grease also allows the fitting to properly spin on the pipe without binding and keeps the threads free from corrosion.
:cheers:
[Modified by Sharky Guam, 8:04 AM 4/2/2002]
Old Apr 2, 2002 | 03:07 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: Fuel Filter (Sharky Guam)
Wow! This is some good advice from Sharky! :cheers: I just did my brother's and my car this past weekend. What a mess! Wished I had waited until this coming weekend...
To Fuel Filter
