Brake Issues any ideas???
Old Oct 7, 2010 | 04:45 AM
89 corvette's Avatar
89 corvette
Default Brake Issues any ideas???
Hey everyone I have 1989 corvette and my brakes are ushaully nice and tight, but the other night I was driving down the highway and I stepped on my brakes and my pedal went down about 80 percent and started slowing down my car and after 1 pump its back to normal, and if I try to brake like 2 mins later it will be nice a tight again but if I wait about 10 mintues the pedal will go down again and ill have to pump it again?.... any ideas? keep in mind it just started happening outa no were?
Old Oct 7, 2010 | 06:39 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Check front brake pads.
Old Oct 7, 2010 | 08:07 AM
DonF's Avatar
DonF
Also check for leaks in the system, make sure that the brake fluid is up to start with. If you have plenty of pads left it sounds like you are getting air in the lines.
Old Oct 8, 2010 | 02:45 AM
89 corvette
yes I checked the brake fluid and its full and I also checked for some leaks and there was non that were visable and my pads are fresh. I drove it around today for a little and it was ok. I will do a complete brake fluid flush this weekend and get back to you guys.
Old Oct 8, 2010 | 08:09 AM
Keystring's Avatar
Keystring
You may have a bad check valve in the booster.
Old Oct 8, 2010 | 08:20 AM
tunedport85inject's Avatar
tunedport85inject
Is master cylinder ok?any leaks around reservoir grommet/bore area:
first ceck for air /water in the line
1) flush the sistem,put new dot 3 into reservoir,bleed the sistem
After bleeding you have a sponge pedal?
yes
2) ceck caliper rubber lines
3)ceck mastercylinder
4)ceck valve booster
Old Oct 8, 2010 | 01:26 PM
Larry/car's Avatar
Larry/car
I think you have an internal leak in the master cylinder. I have seen internal corrosion in the master cylinder so bad that the front and rear systems combined and acted as one system instead of two systems as designed.
Old Oct 8, 2010 | 04:11 PM
ejscarfo's Avatar
ejscarfo
Old Oct 13, 2010 | 09:30 AM
red 90's Avatar
red 90
Do you need a m/c or a booster?? I have both from my parts car. Let me know ... Mark
Old Oct 15, 2010 | 01:51 AM
89 corvette
Thanks alot for the help everyone, I did a full brake fluid system flush and its better then ever, Thanks alot to everyone again
Old Oct 15, 2010 | 08:15 PM
SunCr's Avatar
SunCr
Maybe only temporarily - if it's pushing fluid into the rear because the seal is shot, it's going to blow the top off and you'll end up with fluid all over the battery. Was the front particularly low when you started? I'd keep a close eye on it given the symptoms - in fact go take a look now and if the back is higher and the front lower, you need a rebuild or a new Master.
To Brake Issues any ideas???
