Engine revving
Old Oct 20, 2010 | 04:04 PM
C4MAN66's Avatar
C4MAN66
Default Engine revving
Put a new engine in my C4 and a new transmission a year ago. it was running perfect, now all of a sudden at idle the engine seems like it is hunting. Also not shifting correct now. Not throwing any codes. Anyone ever have this problem before
Old Oct 20, 2010 | 04:08 PM
Siveck's Avatar
Siveck
What year? Throttle valve cable or electronic shift?
Old Oct 20, 2010 | 04:14 PM
sailorsteve's Avatar
sailorsteve
vacuum leak?
Old Oct 20, 2010 | 04:34 PM
Muffin's Avatar
Muffin
Dirty IAC and/or plenum?
Old Oct 20, 2010 | 05:26 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Originally Posted by sailorsteve
vacuum leak?
I suspect same but really need year and conditions,(engine cold/hot etc).....
Old Oct 20, 2010 | 11:55 PM
C4MAN66's Avatar
C4MAN66
89 with tv cable-cable checks out good,I replaced all the vacume hoses when I installed the new engine. Started it earlier, at idle it revs high to low-when i give it gas it stalls.No computer codes still
Old Oct 22, 2010 | 04:13 AM
SQUIRMIN VERMIN 84
try hooking up vacuum guage-how many inches of mercury does it pull? 13 to 16 is good and should be steady with stock cam..
Old Oct 22, 2010 | 03:51 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Disconnect the MAF sensor to see if the idle smooths out.
To Engine revving
