Plans for winter.
Old Oct 20, 2010 | 09:53 PM
94 Z07 VETTE CDUB's Avatar
94 Z07 VETTE CDUB
Default Plans for winter.
Here are my plans for my vette over the winter.
1. Coil-over adjustable shocks
2. Poly- Urethane bushings
3. Cabon fiber interior kit
4. New carpet
5. New leather seats with custom stiching in the headrest ( fathers intials)
6. Hooker long tube headers
7. New exhaust ( magnaflow or corsa )
Sounds like a lot, hopefully it wont be too bad!!!
Old Oct 20, 2010 | 10:21 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Keep us up dated with your progress.
Mike
Old Oct 21, 2010 | 10:12 PM
94 Z07 VETTE CDUB
will do.
Old Oct 21, 2010 | 10:54 PM
VetteTheWorld's Avatar
VetteTheWorld
Sounds like an awesome plan! Last Winter I did a complete brake overhaul; that was fun. This winter, I am getting a few minor paint blemishes re-sprayed. I would also like to get some new Hooker headers for the Vette. Being 17 really puts a damper in my budget, but I do what I can with what I have.
Old Oct 22, 2010 | 01:58 AM
Pwnage1337's Avatar
Pwnage1337
I'm doing a crapload this winter too..
new ECM/harness
383 build..
maybe new bushings for the suspension?
headers
Old Oct 22, 2010 | 05:16 AM
earthquake68's Avatar
earthquake68
This year, all I'm gonna do with the C-4 is keep it clean.
I may add to the Corvette stable by two this weekend. I'm supposed to look at two C-3's. A '79 and an '80. The '79 is the parts for the '80.
IF I get them, the list of things to do will be quite long.
Old Oct 22, 2010 | 04:34 PM
94 Z07 VETTE CDUB
Im glad to see a young kid with a real car and not some rice burner. I too am young (In my 20s) and like my dad said to me when i got my first car(a 6-speed z-28) we are a dying breed.
Old Oct 22, 2010 | 05:28 PM
steverichmond's Avatar
steverichmond
Being a new C4 owner, my winter projects are changing the transmission fliud and filter. Change the break fluid, and new plugs and wires. The PO flushed the radiator last year and the oil was just changed.
Steve
Old Oct 22, 2010 | 05:44 PM
RUU's Avatar
RUU
inb4Frizlefrakaskswhatswinter?
Old Oct 22, 2010 | 05:47 PM
desertmike1's Avatar
desertmike1
Old Oct 22, 2010 | 05:55 PM
Bobzilla's Avatar
Bobzilla
Got myself a long list as well....
Brakes
Hawk HPS Pads
Rotors
SS lines
fluid flush
Suspension
Bushings.... all of them.
Koni's
Maintenance
All fluids changed again.
Tune up (plugs, wires, cap, rotor)
VC Gaskets
general clean up.
After winter, I hope to start the process of putting together all the parts for an engine rebuild. If it holds together until next fall I'll rebuild it next winter and swap to a T-5 at the same time. If not... well we'll see.
Old Oct 22, 2010 | 06:04 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Finally winter is here. The heat and humidity dissipate. I can drop the tops on the verts, take off the top on the coupe , turn off the A/Cs and cruise, cruise, cruise. I love Florida winters. Take some trips down to the Keys or just a ride to the local hamburger joint for an occasional car show. Life is good.
Old Oct 22, 2010 | 06:14 PM
jon0108's Avatar
jon0108
Old Oct 22, 2010 | 06:54 PM
Otis S.'s Avatar
Otis S.
Line Wheel wells
Replace weather stripping
Powder coat/Rechrome wheels
Replace stereo and speakers
Polish
Paint windshield Surround
Replace radio bezel
Replace Headlight switch
Replace Shifter Console
Replace DS window stop
Touch up DS B Pillar
Replace all coolant lines
Flush Brake Fluid
Not really a winter list since I drive my car almost every day. Just a to do list. I am also trying to figure out how to talk the wife into letting my get the front end repainted.
Old Oct 22, 2010 | 08:55 PM
94 Z07 VETTE CDUB
Im glad im not the only one who has a long vette - do list.
Old Oct 22, 2010 | 09:04 PM
1963SS's Avatar
1963SS
I've got a short list but it's mighty
1) Install already built 550 HP LT1
2) Build tranny so it won't explode
3) Change rear to Dana 44
Other the that.....not much.
Old Oct 23, 2010 | 02:19 AM
Otis S.'s Avatar
Otis S.
That sounds awesome. Details please.
To Plans for winter.
Old Oct 23, 2010 | 06:43 AM
littlesk8cracker's Avatar
littlesk8cracker
i hear you man, 19 years old here and budgets are tight. this winters mods are:
1)change ball joints/tie rods
2)upgrade to c5 brakes
3)new black c6 z06 rims
4)lower the car
5)all poly bushings
6)shocks, bigger sway bars
7) dump the spare tire, radio, an more things i find unecesary.
big list, and budget probablly wont allow for all of it, but thats the plan
Old Oct 23, 2010 | 07:41 AM
rickyrj1's Avatar
rickyrj1
My List
1. Install C6 Z06 rear brake calipers & rotors (fronts are done)
2. Install a new custom hood (my own design & build)
3. Install new custom tire delete bracket
4. Install new custom sill protectors
5. Install new coilover suspension ( using CT Machining relocation brackets)
6. polish, polish, & wax, wax
7.
Old Oct 23, 2010 | 11:36 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Mine doesn't need much so I am going to do what I should have done a few years ago. I'm taking out all the Bose amps & wiring and replace with Boston Acoustic speakers at all 4 corners. When someone tells you not to try to run the Bose amps with aftermarket equipment, listen to them. I thought I would be okay with the new Pioneer unit running the Sony speakers through the stock amps,,,,,,WRONG!
