C-4 Shifting Problem
Old Oct 30, 2010 | 06:14 PM
whmartin98's Avatar
whmartin98
Cruising
Default C-4 Shifting Problem
I have 1985 c-4 with a dough nash 4+3 transmission. This problem just started. I can't shift from 2nd to 3rd gear it hangs up in netural and won't allow me to shift. I can down **** from 4th to 3rd gear no problem, and from 3rd to 2nd. I just can't shift from 2nd to 3rd, reverse is fine. Any thoughts, tks Wayne Tn
Old Oct 30, 2010 | 06:18 PM
sailorsteve's Avatar
sailorsteve
Not familiar with that trans, but it sounds like a linkage issue. Maybe something in the linkage has come loose?
Old Oct 30, 2010 | 11:02 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Check your linkage for binding. Sound like that's your problem to me. Your problem does not indicate anything's wrong with the overdrive as just shifting through the 4 gears have nothing to do with the overdrive if it's not turned on.
Old Nov 2, 2010 | 04:45 PM
whmartin98's Avatar
whmartin98
Cruising
Thanks guys for the information you were right. I took it to the transmission shop today and was out in 20 minutest. Linkage adjustment, tks Wayne Tn
To C-4 Shifting Problem
