Keyless Entry
Old Nov 11, 2010 | 01:27 PM
95AquaVette's Avatar
95AquaVette
Default Keyless Entry
Will any Chevy key less entry remote work on a 95 or does it have to be the specific PKE remote? Also would the PKE remotes from 97 or 98 work?
Tony
Old Nov 11, 2010 | 02:45 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
It has to be the C4 specific PKE remote.
No other system works like the one in the C4.
Old Nov 11, 2010 | 04:09 PM
markKlein's Avatar
markKlein
100% correct
Before you buy one test the receiver in your car by performing the fob programming procedure (in the owners manual) and make sure it operates the way it should up until you are supposed to bring the fob in range. No point buying one if the receiver is not working.
Old Nov 11, 2010 | 04:44 PM
jhammons01's Avatar
jhammons01
You don't have to get PKE.....you could also use VKE...but you'd have to push a button...
Old Nov 12, 2010 | 08:00 AM
markKlein's Avatar
markKlein
What?? the C4 factory system is strictly PKE.
Old Nov 13, 2010 | 07:54 PM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Thought so too, I'll wait for the reply on this one.
Old Nov 15, 2010 | 09:57 AM
pitchadude's Avatar
pitchadude
Default test?
100% correct
what is the test procedure? I need one for my 1995.
Old Nov 15, 2010 | 10:14 AM
RollaMo-LT4
It's listed in the owners manual.
If you don't have one, you can download a pdf version for your '95 here.
http://www.gmpartshouse.com/download...95corvette.pdf
To Keyless Entry
