I opened drain on rad until it was empty then put garden hose in rad fill on slow, start your engine, turn on heater and when you see it run clear turn off engine secure drain plug n fill with antifreeze.....
This seems like the most hassle free method.
Are there any drawbacks to this?
I hear back and forth on my 96. Some say dump the dexcool, some say since it came that way just keep using it. I haven't decided what I'm going to do with it just yet.
The worst I've heard is that you do not want to mix dex and the green, and that's where many sludge problems come from.
I didn't see any. I left the t-stat in, its goin to reach temp and the t-stat is goin to open, now your running clear water through the whole system....just remember to account for the clear water in your block when you add your antifreeze.
You bring up a great point. After a flush you end up with a good ammount of water still in the block that does't fully drain out. A trick I learned from high end shops is to add your first gallon of coolant 100% strengh to compensate for the water still in the block. Then 50/50 pre-mixed after the first gallon is in.
If you add 50/50 right from the beginning you'll end up with a more deluted ratio of more than 3 parts water due to the water still in the block.
Well, the LATEST coolant from Prestone is green and says on the bottle it works with anything. I would like to think the images shown are the result of mixing two colors of antifreeze of the old technology.
I have a 97 Saturn with DexCool, and While I wouldn't have picked Dexcool (If i'd had a choice), I've never had problems with it. I flushed it 3 years ago and replaced with fresh DexCool and it's been working happily past 150k miles.
I'm sorry to see a cooling system that clogged. I would normally think that there was something else at work here besides adequate flushing and replacing with wrong color/technology.
Myself, I managed to cook a transmission by putting GL4 synthetic oil in a GL3 only transmission. Cost me $3K to learn that lesson.
The countless lawsuits GM has been fighting over Dex-Cool speak volumes. That set of lower intake gaskets had nothing but dex-cool in it. People will have their own opinions. But as for me I won't put this in any of my vehicles. And I flush it out and refill with green on every out of warranty I do cooling system work on.
You may want to check out Zerex G-05. It is a long life coolant. I put that in my 89.
anybody here hav pics of the knock senors,how many are there
There are two on LT1 and LT4 engines. They are screwed into the threaded holes that had been capped with simple pipe plugs (the cooling system drain plugs) on older small-block Chevy engines.
They are located adjacent to where the downpipes attach to the exhaust manifolds, and on LT1/LT4, they are shielded by steel plates that attach using two of the oil pan fasteners.
