flushing cooling system
Old Nov 13, 2010 | 08:50 PM
itsabigblock's Avatar
itsabigblock
Default flushing cooling system
Having problems flushing the system on my c4 thoughly,I drained the the radiator,fulled it up with distil water, burp it with the car running,ran for ten mimutes with the heater on, temp was fine,shut her down,let it cool for a few hours,drained it again,still green antifreeze coming out,a little lighter in color but still green.I did this three times already still old antifreeze in there,now it started to over heat,what Im I doing wrong?any Ideas would be greatly appreciated
Old Nov 13, 2010 | 09:37 PM
Analog Kid's Avatar
Analog Kid
Many months ago I read a post that said it took the guy 7 cycles of draining, filling, running, draining. If true, you're almost halfway there!
You could pull the knock sensors which will really empty out your block and get all that "hidden" coolant. But since you're halfway there with the fill/drain technique, maybe it's not worth changing tactics. Tough call.
Not sure about why you're overheating except sometimes the burping has to be done multiple times. Last time I did a drain I had to burp it 4 times over the span of 30 minutes.
Old Nov 13, 2010 | 09:39 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
If you only drained the rad, then you left a lot of coolant in the block and expansion tank. Did you pull out the T-stat before you flushed? If it's still in, pull it out, and do the flush again.
Old Nov 13, 2010 | 09:51 PM
itsabigblock
No the T-stat still in, I'll pull it tomorrow and let you know how that works thanks
Old Nov 13, 2010 | 10:00 PM
overdrawn's Avatar
overdrawn
I opened drain on rad until it was empty then put garden hose in rad fill on slow, start your engine, turn on heater and when you see it run clear turn off engine secure drain plug n fill with antifreeze.....
Old Nov 14, 2010 | 02:01 AM
86PACER's Avatar
86PACER
That's your problem. You need to remove the t-stat and reinstall the housing back on with no T-stat for a thorough flush. Go in the car and just turn the key on (engine off) and turn the heater to full hot. This opens the heater valve so the old coolant in the heater core circuit gets fluhsed out too. Now run a garden hose full blast through the thermostat housing till the water coming out the lower radiator hose or water pump at the bottom is clean and clear. Do the same to the radiator with both upper and lower hoses removed and also remove and rinse out the plastic overflow tank to get any last remains of old coolant. Do not add that orange Dex-Cool garbage not matter what anyone tells you. Use green coolant mixed 50/50 such as Peak or Prestone.
When refilling park uphill or raise the front of the car up to make the radiator the high point in the system.
Old Nov 14, 2010 | 08:10 AM
Mark_Sheehy's Avatar
Mark_Sheehy
I have a Prestone flush-n-fill kit on my 89 L98 and it works great for flushing out the old coolant. Plus when I am done I raise the heater hose where the valve is at and fill it from there as it is the high point in the system. I also put the front end on jackstands which I think helps eliminate air pockets. I leave my thermostat in and haven't had issues.
Old Nov 14, 2010 | 09:33 AM
96_vette's Avatar
96_vette
An older post of mine.........
http://forums.corvetteforum.com/c4-t...g-storage.html
Old Nov 14, 2010 | 09:48 AM
Donne Trav's Avatar
Donne Trav
What is the general burping procedure? (Engine running, cold or hot, etc,)
Old Nov 14, 2010 | 10:32 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Your engine has to be hot for the thermostat to be open for circulation. I drive my vette on my ramps, open the coolent cap, run the engine up to about 1500 rpm and fill then. You have to put the cap back on before you let the rpms drop. I agree that it can take a couple burps to get all the air out.
Mike
Old Nov 14, 2010 | 11:01 AM
jon0108's Avatar
jon0108
Old Nov 14, 2010 | 03:44 PM
itsabigblock
theres a little screw right on the neck of the t stat housing, you open that screw a little w/ engine running to let any air thats traped, you'll see it start to **** out than close it.
Old Nov 14, 2010 | 08:29 PM
86PACER's Avatar
86PACER
Purge valves on the T-stat housing didn't begin till about '92. All C4's before that had none.
Old Nov 14, 2010 | 08:41 PM
helphos's Avatar
helphos
Default Flushing coolant
Well, You probably won't do too bad by leaving the tstat in and driving around till it opens and putting the heater on. Then Drain it one last time, ignore the color, and fill it with 50-50 Green antifreeze. I agree with the crowd who says to avoid Dex-cool.
But two or three drain/flush cycles is enough if you do it every 2-3 years.
We're talking about a car here, not a human.
If you want to give it a 'treat' add a bottle of Water-Wetter. It will help keep temps down.
Also, while you're at it, clean the area between your radiator and your AC condenser (or is it the evaporator?). I found a mouse nest in mine.
Good luck!
Old Nov 14, 2010 | 09:26 PM
roadrashrepairman's Avatar
roadrashrepairman
So it was a warm day today and with all the coolant changing going on, I did mine. Changed it until the coolant ran clear filled it with a 50/50 mix of the green stuff. Ran it until tstat opened with heat refilled all with additional 50/50. Now my low coolant light comes on when I start up and goes away after I drive for .5 miles. Check fluid levels are good both cold and warm. Any suggestions?
Old Nov 14, 2010 | 09:28 PM
86PACER's Avatar
86PACER
You need to pack the radiator over the course of the next few days. You still have an air in the system so when you're driving the coolant level drops below the level of the sensor on the radiator and illuminating the light sporadically.
To pack the radiator means to top off with the engine RPM's held at about 1500 or so. Raising the RPM's drops the level in the radiator after the stat has opened. Put the cap back on before letting the RPM's back down. If you have a pre '92 which has no purge valve it helps to park uphill or raise the front of the car with a jack to make the radiator the high point in the system. Also have the heater on full hot and running during this so the heater core circuit is open and everything is fully circulating.
Old Nov 14, 2010 | 09:35 PM
roadrashrepairman
Thanks for the tip. Will do. It's dark here now so I'll start tomorrow
To flushing cooling system
Old Nov 14, 2010 | 09:38 PM
86PACER's Avatar
86PACER
Just open the cap and top off if there is space in the radiator before you start the car tomorrow. Then once hot and after the stat has opened (about 200 degrees on dash) slowly twist the cap with a rag over it releasing the pressure and pack it the rest of the way as I mentioned above. This is where having one of those vented caps with a release lever comes in handly.
If you don't want to do it that way you can also just keep topping it off cold first thing in the morning over the course of the next several days till you can't add anymore. Of course you actually have to drive the car during the day though to help purge out the air.
Old Nov 15, 2010 | 03:20 AM
enventr's Avatar
enventr
I read the chemical composition on the prestone 50/50 and I also read the same for the dexcool-looks like it is the same chemical composition ??
Old Nov 15, 2010 | 04:21 AM
86PACER's Avatar
86PACER
They are different. Dex-Cool is garbage and doesn't belong in these cars. This is a lower intake manifold gasket I replaced not too long ago on a Chevy minivan with Dex-Cool in it. All that orange gunk is from Dex-Cool. That is what I find over and over inside most of the Dex-Cool vehicles I've worked on. Even cars just a few years old. I never see this on green coolant cars. On this car I had to toss out the radiator and cap as well as the T-stat and water pump. GM has been sued over Dex-Cool countless times and shops see this every day.
Stick with green coolant mixed 50/50 with distilled water. I like Peak.
