Wind deflectors
Old Nov 24, 2010 | 08:23 AM
jeffp1167's Avatar
jeffp1167
Originally Posted by Phat98
YES! Put them on my '94...seems like it quieted the wind noise a bit. The biggest difference is when I smoke with the window cracked open I don't get a faceful of ashes whipping through that gap.
Mine are riveted on and there is about 1/4" space between it and the weatherstrip.
Can I see more pictures of the wind deflector on your hood?
Old Nov 24, 2010 | 08:51 AM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Yep, have them on my 95, riveted to mirror. They definetly deflect air but I also use the rear window hatch extender (about $30 in most of the catalogs), that really lets the air slide through with no buffeting.
Old Nov 24, 2010 | 11:24 AM
peterg943's Avatar
peterg943
Thanks for the responses, I will order them today!!!
Old Nov 25, 2010 | 03:16 PM
Vintagevetter's Avatar
Vintagevetter
Default Paint Them
I always thought that unless they were painted the same color as the car...they looked...tacked on.......something you might pick up at Pep Boys.
Old Nov 25, 2010 | 07:28 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
my `87 came from the factory with them. I can`t notice too much difference between it & my `90, but the whine from the supercharger on the `90 might have something to do with that.
Old Nov 26, 2010 | 05:39 PM
Warren Seale's Avatar
Warren Seale
When did they start becoming available from the factory? Was it an option or standard equipment?
Warren
Old Nov 27, 2010 | 11:10 AM
Siveck's Avatar
Siveck
They came on all verts and '87 coupes. The factory ones fit better than the aftermarket ones.
Old Nov 27, 2010 | 02:25 PM
Z51JEFF's Avatar
Z51JEFF
They came on convertibles and were an option on coupes I believe.They do work they just fit really poorly.I took a set I had,changed the contour abit,pulled a mold off of these and made my own set.Cant post any pictures at the moment.
Old Nov 27, 2010 | 08:38 PM
pay the mechanic's Avatar
pay the mechanic
[QUOTE=Phat98;1576018964]YES! Put them on my '94...seems like it quieted the wind noise a bit. The biggest difference is when I smoke with the window cracked open I don't get a faceful of ashes whipping through that gap.
Old Nov 27, 2010 | 09:20 PM
jeffp1167's Avatar
jeffp1167
Originally Posted by Vette Jockey
I notice a definite difference when I have the top and windows down
Here is a closeup of a factory unit. You can see why it helps with the noise. My only problem is it rubs against the weather stripping. I dress it now and that seems to help.
maybe that black plastic piece between your mirror and door is upside down. I have the factory deflectors and they clear my weatherstripping just fine.
Old Nov 29, 2010 | 01:54 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
These are some type of metal, factory installed, and are rivited on. They came standard on the '95 vert. But, I see what you mean. Maybe it was a Monday car and somebody had a hangover and was not seeing to well. I will have to check out another '95 vert. Thanks for the tip.
Old Nov 29, 2010 | 02:54 PM
techvette's Avatar
techvette
When I bought my car the driver side had one but not the passenger side. There was definitely more turbulence on the passenger side. I have since put one on.
Old Dec 4, 2010 | 08:19 AM
  #33
jeffp1167's Avatar
jeffp1167
I bought mine off the bay they came with the GM boxes. If yours are metal maybe that could be the problem. Mine are made of plastic, I didn't even be a perfectionist in drilling the mirrors and riveting them on and they clear the weatherstripping fine. Maybe they are not factory ones and have back to back tape still holding them on and someone then riveted them in place and it is the tape thickness that is pushing them closer to the weatherstripping.
Old Dec 4, 2010 | 12:24 PM
  #34
Z51JEFF's Avatar
Z51JEFF
These are plastic and next to impossible to get them upside down.When making these I found the mirrors are not mounted on the doors exact side to side.I also found one deflector is 5/8 of an inch shorter than the other.
Old Dec 4, 2010 | 12:59 PM
  #35
jeffp1167's Avatar
jeffp1167
mine basically rise above the weatherstripping but don't touch it.
