Headlight motor question
Old Nov 27, 2010 | 02:27 PM
Evil2live's Avatar
Evil2live
Default Headlight motor question
I recently purchased a replacement headlight motor for my 85 and noticed that there is what appears to be an "L" shaped fitting on the housing of the new motor,similar to a vacuum fitting. I hadn't seen this on either of my original motor housings and after closer inspection discovered that the fitting had been there but broke off at some point before I owned the car.
Does anyone know what these fittings are for? I don't even see anything that might have hooked up there at some point.
Old Nov 27, 2010 | 03:00 PM
1985nightmare's Avatar
1985nightmare
i always assumed that was where you pumped grease into to lube the gears but when I took the motor apart I noticed the hole exits where the shaft and spring assembly is so that can't be it. Good question, maybe someone else can chime in.
Old Nov 27, 2010 | 06:57 PM
oldalaskaman's Avatar
oldalaskaman
I think its a drain for moisture
To Headlight motor question
