clueless: check engine light
Old Dec 12, 2010 | 03:25 PM
littlesk8cracker's Avatar
littlesk8cracker
Default clueless: check engine light
so heres the rundown. about 2 weeks ago i changed out the exhaust on my car, new cats and catback. the next day the car broke down on me and wouldnt start. got it home and after messing with it a bit, i changed the icm and the car started right up. its run fine since then, but has had a check engine light. i pulled the codes and it was h42 and h62. h42 is ignition control circuit shorted. h62 is Engine Oil Temperature Sensor Circuit Voltage Low. now, once the car warms up to about 185-190, the check engine light goes away. its only on when the car is under that temp. so does anyone have any clue what it could be? the only idea i have, is that when i removed the driver side cat i had to remove a bolt that grounded 3 wires and a ground strap. they were grounded to the bracket that held up the cat. well the new cat didnt have that bracket, so i just cut the piece off the old one so i could still have something to ground those wires too. is it possible that they dont have a good ground and thats causing my problem? thanks!!!!
Old Dec 12, 2010 | 03:36 PM
blr33439's Avatar
blr33439
If it was working OK before, then you probably caused damage or broke something loose when changing the cats. I would start there. Also, if you reattached ground straps, I would make sure they are making a good connection and not insulated along the grounding path.
Also, was the ground strap connected to the frame or cat previously. You make it sound as if you have attached the ground straps directly to the cat this time. That is probably not the best ground location.
Old Dec 13, 2010 | 02:35 AM
littlesk8cracker
there was a bracket holding the cat up, that got attatched to the frame or tranny, i forget. i just grounded it right back to that spot
Old Dec 13, 2010 | 12:03 PM
sailorsteve's Avatar
sailorsteve
You could check your new ground with an ohmmeter to a known good ground, should read zeroish.
To clueless: check engine light
