**First Vette-Lowered or Sagging?
Old Dec 14, 2010 | 12:07 AM
Stryker7's Avatar
Stryker7
Default **First Vette-Lowered or Sagging?
Hey folks! After months and months of searching, I am finally in the process of purchasing my first vette. I have always loved the C4 body style and thought a car that marked my wedding anniversary would be special, not to mention its a 40th Anniversary edition and holds some value. As you can imagine, after months of looking I had gathered quite the collection of pictures in the 92-96 years. The owner gave me a picture of it to take with me while the bank was gongkulating the final numbers and as I looked more and more I noticed the sag in the back as compared to other cars with the same care and mileage (sub 60k). Given my virginity in the world of corvettes, I thought I would solicit the opinions of the forum. How do you know if a vette has been lowered vs. the suspension is tired / sagging? I have pulled pics of new C4s and they have a nice 2.5-3" gap on the rear tire whereas the one I am buying only has an 1-1.5. Is there a way to readily tell?
Thanks group...great to be here!
Need to plug into some of the cruises going on in my neck of the woods.
Dave
1993 40th Anniversary: 41,000 original miles: Delivery on Friday 17 Dec.
Old Dec 14, 2010 | 12:49 AM
Eakster's Avatar
Eakster
Can you post the pic?
Never heard of C4 sagging issues. The composite leaf spring technology is supposed to have more longevity than conventional wound steel springs.
Also many people lower their cars. Sometimes they only lower the rear as it is a simple turn of 2 bolts, as opposed to dropping the front which requires significantly more work.
Ask, no, cross-examine the owner about the car's history.
Old Dec 14, 2010 | 01:23 AM
Stryker7's Avatar
Stryker7
The car has 41k and the owner stated that he had the composite spring replaced due to a crack. However, he has only owned it for 18mo or 4000mi. The piles of paperwork and original documentation might have the answer but from looking at other vettes and based on your explanation, it appears to be lowered. The car looks like it has been babied and under a cover for years. Unfortunately I don't have pics hosted on a site and I don't see where I can post a pic to this site directly from my hard drive. Any suggestions? Thx for the post and help.
Old Dec 14, 2010 | 01:25 AM
CRUZNC4's Avatar
CRUZNC4
2022 C4 of the Year Finalist - Unmodified
Welcome to the Forum! How about a pic or two of your Vette.
Old Dec 14, 2010 | 01:28 AM
dogfish246's Avatar
dogfish246
Test Drive!!! That is the best way to know if it has been lowered or if the leaf springs are shot... If she is solid and drives like a Vette should drive then you are probably good! Also check the spring for any visible cracks! Good Luck with the purchase!
Old Dec 14, 2010 | 01:34 AM
Eakster's Avatar
Eakster
Oops - welcome!
A lot of people here use Photobucket. Just register and upload your pics there. It will give you the code under each pic to post it here. Also this
Old Dec 14, 2010 | 08:21 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum Dave I have seen a few cars that were only lowered in the back because as stated above the front takes a lot more work. Ask the seller for a reason the back is lower or if you want to feel at ease about this have it checked out first.
Old Dec 14, 2010 | 08:30 AM
89ragtp's Avatar
89ragtp
Welcome aboard!
Old Dec 14, 2010 | 09:23 AM
Churchkey's Avatar
Churchkey
Take a look at the rear spring hanger bolts. Stock bolts are black in color & have a castellated nut with a cotter pin.
Longer aftermarket bolts are required to lower the rear & normally use a self locking nut without the castellated feature.
Old Dec 14, 2010 | 12:53 PM
F40's Avatar
F40
Old Dec 14, 2010 | 11:20 PM
Stryker7's Avatar
Stryker7
I will take a look. Thanks for the great tip.
Old Dec 15, 2010 | 01:36 PM
slickfx3's Avatar
slickfx3
all the bushings can stretch and you will get sag
Old Dec 15, 2010 | 06:43 PM
pay the mechanic's Avatar
pay the mechanic
C4 corvette rear sagging ??????
what........................
i saw acouple 90 model Lincolns and some Thunderbirds sagg in the rear
Old Dec 15, 2010 | 09:04 PM
mike100's Avatar
mike100
Maybe they don't all do it, but mine was listing on the driver side rear. I just bought a longer spring to knuckle bolt and lowered the good side to match (about an inch difference).
Old Dec 15, 2010 | 09:20 PM
Stryker7's Avatar
Stryker7
Perhaps sagging was the wrong word given the implications. Both sides are even and it does drive like a vette (as I would expect having not owned one). Regarding pics, there is a message at the bottom of my original post that says that I am not allowed to post attachments (e.g. pics). Perhaps that is an extended feature for paying customers.
Old Dec 15, 2010 | 10:46 PM
Stryker7's Avatar
Stryker7
Originally Posted by oldalaskaman
If the gaps are pretty close to equal on all four wheel wells, its probably been lowered. There a few different ways to lower these cars, longer bolts only being one.
Do folks typically 'cut' the springs on these vehicles to achieve that affect or is it usually with longer bolts?
Old Dec 15, 2010 | 10:53 PM
pay the mechanic
very nice looking car
i always wanted a C4 Corvette THAT color
To **First Vette-Lowered or Sagging?
Old Dec 15, 2010 | 10:58 PM
mike100's Avatar
mike100
C4's have tranverse composite leaf springs, so no, they aren't cut. you alter the arc or preloaded bend on the springs with different length bolts that tie them to the rear hubs. raising or lowering the initial spring rate sets the ride height up or down a couple of inches.
just get stock bolts and raise it back up or get bolts that are nearly the stock length to have it semi-lowered. (shorter bolt = higher stance).
Old Dec 15, 2010 | 11:15 PM
Churchkey's Avatar
Churchkey
Spring are a composite monoleaf mounted transversly. Modifications to them will end in component failure.
Besides long bolts to lower the rear the spacer blocks between the top of the spring & cradle could be removed or a softer spring could be used. Other than those 3 methods letting the air out of the tires is the last option.
The front spring uses a similar mounting system as the rear at the center however the ends contact the lower control arms directly without the hanger bolts.
As far as the pic you posted in your first thread: SWAG, looks like 12" long bolts were used to get the rear as low as it is. There may be some thread left on the bolts above the nut, if so you can run the nuts up to raise the rear. Suggest 1/2 tank of fuel when adjusting chassis heights.
The front of the car appears to be at stock height.
Long wait until Friday no? Hope the weather is good for you.
Old Dec 15, 2010 | 11:22 PM
Stryker7's Avatar
Stryker7
Spring are a composite monoleaf mounted transversly...looks like 12" long bolts were used to get the rear as low as it is....Long wait until Friday no? Hope the weather is good for you.
Thx to Mike100 and Churchkey for saving a guy from his ignorance. That gives me some peace of mind. I have spent some time checking out suspension pics of how things are bolted together on a vette and it seems fairly simple and common (lowering). Wonder if it shortens the life of the monoleaf to lower the car like that. Regarding Friday, I went up yesterday to take delivery but the buyers credit union wouldnt accept the check my bank sent them, so we have to wait until it clears before they will release the title. You are right though...Friday seems like 'years'!
