275 ?
Jan 27, 2011 | 04:03 PM
275 ?
will 275 tire fit on the front ? i got a 96 ce auto
Jan 27, 2011 | 04:08 PM
depends on your front wheels' width...8.5'' = best not to go with 275s... 9.5'' is ok.
Jan 27, 2011 | 04:13 PM
I've run 315's in the front with no issues. Are you asking for stock rim size to put a tire on or a different set of rims and tires?
Jan 27, 2011 | 04:14 PM
C4 of Year Finalist (appearance mods) 2019
YES I have 275x40x17 on all 4 corners ... but like the previous post .... these are all on 9.5" wheels.
Jan 27, 2011 | 04:27 PM
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
275/40-17 on 9.5" wheel on the front of my '96.
I wouldn't put a 275 tire on an 8.5" rim though.
Jan 27, 2011 | 04:55 PM
Quote:
Originally Posted by
Daniel_Mc
what was you rim size and offset, stock?
Jan 27, 2011 | 07:13 PM
slickfx3
It was just the AFS A Mold wheels with the GS offset. I never did try to turn the car to full lock I was running some Hoosier R6's on them at TWS. I felt it made the car push with the bar that i was running and went back to 295's
Daniel
Jan 27, 2011 | 07:33 PM
Many 96s came with 275s on all four corners... its a 17x9.5in rim...
Reason: Wrong info
Jan 27, 2011 | 07:38 PM
Mr. Peabody
I also thinking new wheels and tires
What wheel offset do you have?/
I see 56,54,50.I don't know what would be best putting 275 on all 4's
Jan 27, 2011 | 07:49 PM
dogfish246
All 96s came with 275s on all four corners... its a 17x9.5in rim...
No, they did not.
The base suspension cars came with 255/45-17 front on an 8.5" wide wheel, and 285/40-17 rear on a 9.5" wheel.
And you could get the CE with base suspension.
Jan 27, 2011 | 07:51 PM
RollaMo-LT4
No, they did not.
Really? I thought all 96 came with 275s wow... Good to know!
Jan 27, 2011 | 08:10 PM
St. Jude Donor '10
tblt44
Offset has nothing to do with tire size. This is how the wheel sits on the hub/inside the fender.
Difference between 56,54 and 50 is almost all the same. 56mm vs 50mm is 6mm- less than 1/4".
What year is your car? (too lazy to look at profile)
Jan 27, 2011 | 11:42 PM
I have 275-40-18's on all four corners, 9.5 width, 55mm offset. No issues with rubbing lock to lock. Vette is a 90 @ stock front height.
Jan 28, 2011 | 03:09 PM
try looking at the specs page on tire rack. It lists the rim sizes suggested for different tires.
I generally agree that a 275 should have the 9.5 wheels, but a few tires like the Goodyear GSC stated OK on an 8.5.
Another option is the Camaro SS wheel that looks just like the CE wheels but is 9"
Jan 28, 2011 | 06:48 PM
I have 285's on all 4 corners w 9 1/5 wheels on my collector conv no problems
