Air Conditioning question
Old Feb 20, 2011 | 01:26 PM
#1weatherman's Avatar
#1weatherman
Default Air Conditioning question
I bought a '92 LT1 Coupe a few days ago and I have a question about the heating/cooling system. Is there a way to shut the air conditioner compressor off during the winter when you don't need it except for the occasional window defrosting? I see no place on the control panel to deactivate/deselect the compressor. It seems that no matter what mode you're in, the compressor continues to cycle on and off. It's not a biggie, just looking for a way to save a little fuel whenever possible.
Old Feb 20, 2011 | 01:39 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
When you select "Vent" mode, the compressor will not run.
Vent mode is the icon with the single arrow pointing at the figures head.
Old Feb 20, 2011 | 01:58 PM
sailorsteve's Avatar
sailorsteve
That's correct, the compressor is declutched, and although the pulley rotates, the compressor is not engaged.
Old Feb 21, 2011 | 11:58 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
The air conditioner does not work if the ambient temps are below 40*F.
To Air Conditioning question
