I know the wheel adapter thing has probably been covered more than anyone cares to remember, but... What is the difference between a hub centric and a standard adapter?
I recall reading a post on here (somewhere) suggesting I buy only hub centric adapters. I see the price difference is approximately $20/pair for a wheel adapter vs. hub centric.
I'm putting them on an '84 to bolt on a set of '99 wagon wheels (17/18 staggered) I'll be using 1" front 1.25" rear.
With the tapered acorns that Chevy uses, you really don't need hubcentric, but I bought mine that way anyways. If anything, it helps you set the wheel on prior to getting a couple lugs going. Of course, put the lugnuts on properly, hand tight and cris/cross star shaped, then light wrench, then torque 50ish, then again at 100.
Cars like BMW and any other using straight type lug nuts need hubcentric or the car will shimmy and shake no matter how many times you balance the wheels (ask me how I know).
I did the 3/4 for over a year but if i knew before 1" would be better.-
i bought from rigged.up seller on ebay
pretty good quality ,prices and service !
Ask him for 3/4 but i would go with 1" hands down !!!
In fact i got 1.25" on fronts and 1" on rears
for my C5 Fikse wheels
The 1" adapters i mentioned above are perfect,the stock studs do not have to be grinded or shortened at all, and this includes the recess to hide the nuts.
Dude, get these hub centric adapters. They have that extra piece in the middle circle that sticks out and you will feel safer driving and they are stronger. Standard adapters do not have that extra piece in the middle circle. For a few dollars more and safety I go with hub-centric.
Those are what I'm looking at, from ezaccecessory. Why are they better and/or stronger? I don't understand how the lip around the hub makes them any different? The guys at ezaccessorry told me it's only for clearing your wheel hub, and is not necessary on all cars.
For me I feel like they are locked in more and they just make me feel safer when driving, especially with having any size wheel adapters on your car. It is just the feeling of extra support and like I said for $6 more why not get hub centric. In the end, to each is own.
I would also like to add that when you put on a set of hub centric adapters you get that extra sense of security and feeling of them kinda locking into the hub compared to basic adapters that do not give you that sense of security. I hope you understand what I am trying to say here. Like I said only $6 more each. Safety is important to me at 120 mph. Good luck.
It's a $15-$25 difference per pair. I'm honestly clueless when it comes to why one is better than the other? All the vendor can tell me is that I may need hub centric to fit properly.
From what I can find researching the differences, the center bore is large on hub centric (in this case anyway) and they have the lip to help keep the wheel centered. But like was stated earlier given the GM flared wheel nuts they center the adapter up well. (according to the vendor this is the case also) Apparently some wheel adapters require mag nuts with the long shank to help keep them centered, these apparently do not require that.
@uptown. I get what you're saying and I appreciate your feedback. Thank you.
This is exactly why I posted this question. I honestly don't know which way to go and if one is better than the other. Seems to be one of those things that everyone has an opinion on, and I don't know if one way is better than the other or not?
Sorry, I meant to say $5 difference for each pair since they are sold in pairs. The ones from riggedup are $70 and ez-accessory are $75 making is a $5 difference in a pair.
I was told to buy hub-centric and that is what I did, mostly for safety reasons. I am using the nuts that came with the adapters and haven't have any problems. I also like hub-centric because it keeps the wheel centered as well. Just get those and you will be happy.
Like socalman said above, there are many types of cars where this would be true and hub-centric is a must. Our Vettes are not among those types of cars.
If you get them they won't hurt anything but they aren't needed and they are no safer. They make it a little easier to line the wheel up when you put it on but that's about the only gain.
Feels safer to me, that is what is important and its only a $10 difference for 2 pairs so don't be cheap get hub-centric.
regardless of how little, there MUST be SOME clearance between the 'hubcentric' protruding ring and the wheel...if there was '0' clearance the wheel either would not go on, or would 'make room'...the lug nuts ('bulge' acorn type, only, please) DO go to '0' clearance when tightened, precisely locate the wheel on the hub face, and (if made correctly) leave the hubcentric ring 'lost in space' and useless.
