VATS??????
Old Apr 14, 2002 | 10:25 PM
traceyvette's Avatar
traceyvette
Cruising
Default VATS??????
I bought my 1984 vette used. I don't know how to work the anti theft system. It has never gone off. When I get into the car in the mornings, the security light is flashing. Then goes off when I start the car. How can I check to make sure it is working?
Old Apr 15, 2002 | 12:09 AM
VetteBabe1's Avatar
VetteBabe1
Default Re: VATS?????? (traceyvette)
This is how I got mine to set off:
Roll down your window on the driver side.
Lock your doors, and wait for about 2 minutes.
Reach in over you door and unlock your driver's door from the *inside*, then open your door from the outside.
The horn should start beeping incessantly.
To turn it off, put the door key in the door and turn as if you were unlocking.
That is what worked for me in setting my 87 off, usually accidentally. :)
[Modified by VetteBabe1, 10:10 PM 4/14/2002]
Old Apr 15, 2002 | 12:12 AM
scorp508's Avatar
scorp508
I'm pretty sure there is no VATS in 84. (The little resistor in the ignition key)
To arm your car alarm you must take the keys out, open the door, and lock the doors with the power lock switch. You should see the security light go from blinking to solid. Shut the door and security should turn off within 3 seconds. After that if a door or the hatch is opened without unlocking with a key, the alarm will sound.
Old Apr 15, 2002 | 12:17 AM
VetteBabe1's Avatar
VetteBabe1
Default Re: (scorp508)
I didn't know that, interesting. Wonder why it blinks "security" then? Hmmmm. I guess we'll find out if she tests it! :)
Old Apr 15, 2002 | 11:08 AM
2 Ag R8Cs's Avatar
2 Ag R8Cs
From: Retired Suffolk County Police Dept NY South Carolina
Default Re: (VetteBabe1)
I don't recall one in my 85 either, last owner may have added it
Old Apr 20, 2002 | 06:51 AM
2 Ag R8Cs's Avatar
2 Ag R8Cs
What ever happened with the VATS? did it have it added buy a former owner as a mod?
To VATS??????
