Rear Cargo Struts
Old Mar 20, 2011 | 01:38 PM
VA50th's Avatar
VA50th
Default Rear Cargo Struts
The rear hatch on my 96 coupe opens fine. A bit slow, but it does open. However, when I close it I can hear a slight squeaking sound. What is the best option to lube the struts? ...and where do you actually put the lubricant?
I've got some white lithium grease (spray), WD40, 3-in-one oil.
Old Mar 20, 2011 | 03:34 PM
oldalaskaman's Avatar
oldalaskaman
I vote , white , only spray it on a rag and just wipe it lightly
Old Mar 20, 2011 | 04:07 PM
06_LT1's Avatar
06_LT1
I use high-end clear bike chain lubricant on mine - Pedro's, usually.
To apply, I run a thin bead along the length of the piston, open and shut the hatch a few times to make sure everything gets coated, and check for drips.
Old Mar 20, 2011 | 04:57 PM
socalman's Avatar
socalman
St. Jude Donor '10
I vote Steak Sauce. 'A1' to be precise.
To Rear Cargo Struts
