87 windshield wiper problem
Old Apr 15, 2002 | 05:56 PM
PJSALERNO's Avatar
PJSALERNO
Default 87 windshield wiper problem
Greetings all, maybe you can help...
Symptom:
The windwhild wiper motor only works on the highest switch setting. When the switch is then set to the off position, the blades do not retire to the original position, they just stop where thy are.
I mistakenly replaced the switch only to have the same symptom. Is there a module or relay to check/replace or is the motor itself the problem.
Any help is well received......
Phil 1987 Coupe Dark Red Metallic. 35k :flag
[Modified by PJSALERNO, 3:56 PM 4/15/2002]
Old Apr 15, 2002 | 08:25 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: 87 windshield wiper problem (PJSALERNO)
sounds like your terminals are dirty or loose at the windshield wiper motor. turn it on and wiggle them.
Old Apr 15, 2002 | 10:10 PM
JonM's Avatar
JonM
Usually if you only have hi wipers, its the motor. Make sure the wiper motor mounting screws are tight and the ground is good.
Old Aug 16, 2019 | 12:47 PM
Bigdick's Avatar
Bigdick
My 1989 c4 wipers work on high and low. Intermittent and park inop. Any ideas as to repair needed.
Old Aug 16, 2019 | 04:13 PM
3D-Aircrew's Avatar
3D-Aircrew
Symptom:
It's the switch in the wiper motor. You can R&R or try to fix it.
To 87 windshield wiper problem
