Removing Air cleaner housing locking knobs????
Old Apr 16, 2002 | 06:24 PM
PJSALERNO's Avatar
PJSALERNO
Default Removing Air cleaner housing locking *****????
I feel ignorant asking this...but how do you remove the 2 Air cleaner housing locking *****. They just spin without loosening or tightening. Thanks...phil :flag
Old Apr 16, 2002 | 06:34 PM
Pete Clough's Avatar
Pete Clough
Default Re: Removing Air cleaner housing locking *****???? (PJSALERNO)
Mine did the same thing, if I remember right I took a large flat bladed screwdriver and shoved it under the housing and pushed on the screw shaft to hold it tight while unscrewing the *****.
PC
Old Apr 16, 2002 | 07:11 PM
vader86's Avatar
vader86
Default Re: Removing Air cleaner housing locking *****???? (Pete Clough)
its a little trick getting them things off, i put my screwdriver in and pushed up while turning, i dont believe there was any real thread in there for them to screw into.
dont feel stupid for asking that one
Old Apr 16, 2002 | 11:40 PM
LWesthaver's Avatar
LWesthaver
Check out this Tech-Tip:
Plenum Studs
It may be of some help to you.
Old Apr 19, 2002 | 07:40 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Removing Air cleaner housing locking *****???? (LWesthaver)
I coaxed mine out by using a shop towel so I could get a decent grip on the *****, but mine were slightly rusted and were a major PITA to twist out.
When putting them back in, I coated the threads with some grease and next time to service the air filter it was a lot easier.
Old Apr 19, 2002 | 08:12 PM
carter200's Avatar
carter200
Default Re: Removing Air cleaner housing locking *****???? (onedef92)
Be careful when putting them back in as there is a particular spot for the short and long ones. Don't mix them up :crazy: :seeya
To Removing Air cleaner housing locking knobs????
