Help with Driven Gear?
Old Apr 1, 2011 | 05:10 PM
adfac's Avatar
adfac
Default Help with Driven Gear?
I'm changing rear ends from 2.73 to 3.73 on my 86 (automatic / Dana 36). I think the correct speedometer driven gear for the 3.73 is a 45 tooth, light blue, GM Part #25513052. I could not find it at Ecklers, MA, or GM Parts Direct but I did find it at RMS Auto Parts (http://www.rmsautoparts.com/proddeta...25513052&cat=5) but it shows "out of stock". Could someone tell me if I have the right part and does anyone know where I might be able to find one? Thanks.
Old Apr 1, 2011 | 06:15 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
http://www.ringpinion.com/PartsList....D=139&CatID=35
Before you do this speak with some owners using 3.73 gears in an automatic.
There is a big difference between 3.73 auto and 3.73 manual.
Old Apr 2, 2011 | 05:13 AM
toptechx6's Avatar
toptechx6
That looks to be the correct driven gear for your swap, I know it is the one I used in my 93 when running that ratio and my speedometer was accurate. It must be matched with the 15 tooth gray drive gear.
Give this link a try.
http://www.transmissioncenter.net/sp...n_______va.htm
If you strike out finding a new one, let me know and I'll look for my old one, good luck.
Old Apr 2, 2011 | 05:21 PM
Jimbo 89's Avatar
Jimbo 89
I think you would be happy with 3.07 performance axle for street use. Drag strip, I could see 3.73's
Old Apr 3, 2011 | 06:55 AM
UNCLEBILL's Avatar
UNCLEBILL
On my 1990 Vert auto; I went from 2.73 to 3.54 and very happy with the SOTP pull. I used a 43T driven gear.
Bill
Old Apr 4, 2011 | 01:14 PM
adfac's Avatar
adfac
So you think 3.73 might be a little bit much in an automatic?
To Help with Driven Gear?
