Raw gas smell
The C4 I just bought (1991) was at a car lot for 2 months on an almost empty tank, and it appears to have dried out the gaskets around the tank or somewhere else. Since filling the tank, it's had a very strong gas smell, especially when it's warm outside.
It doesn't smell like gas anywhere near the engine itself, so I'm not too worried there, and it's worst right at the back left wheel well. I've tried to look around but I'm not familiar with the car yet, and didn't find anything.
I've driven almost a tank's worth so far and the smell hasn't subsided, so it's not just a "full-tank" issue. I'm also getting decent mileage and have found no leaks or wet spots, so it seems to be gas vapor rather than a full on leak.
Anyone have any suggestions as to where I should look? Thanks in advance for the help!
http://forums.corvetteforum.com/c4-t...ce-1986-a.html
Im also new to these cars..
If you figure it out let me know what you found, and I'll do the same!
easy to fix...
might bash a knuckle or two... its tight...
Philip
easy to fix...
Philip
The old ones just stuck to each other when I squeezed them
