PKE Programming help on a 94
from the om:
Turning the System Off
1. Take the ignition key out of the ignition.
2. Press DOOR on the transmitter until the door locks
cycle (about two seconds).
To turn the system back on, just repeat the steps.
To check that the system is off, turn on the ignition. The
PASSIVE KEYLESS ENTRY light on the Driver
Information Center should not come on If the light does
come on for a second or two, then the PKE systemis
still on.
You can also check whether the system is on by
closing the dooar and moving away from the vehicle
with the keys and transmitter. If the doors lock, the
system is on.
If you are working around your vehicle and keeping
your keys with you, you might want to turn the PKE
system off. If you don’t, the transmitter will keep
locking and unlocking your doors.
Do a search here in the forum for this topic has been discussed before. Don't give up. Unless the pke module is dead
(behind central dash) it could just be 'asleep'.Good luck!
i dont know why when i try to set the fob to work it will not work. i know the manual says turn the key off and leave it in the ignition and when doing so the light does not blink when its suppose to blink. it turns off with the key and does nothing. has me puzzled
Gitusum, any update?
