I drive a '96 daily (commute). It has 105K and is running great.
The plugs and shocks have never been replaced.
I need to know what are some really good shocks/struts one would recommend. Also, what about bushings? is it time to replace these items as well as some others? I plan on driving the car till the wheels fall off.
All reg. mnx has been done, oil, filters.
And while it's up on the rack, what is a good idea to service since it's in the air?
So Mike tell us a little bit more about your car.
Is it an automatic (LT1 engine) or a 6 speed (LT4 engine)?
Does it have a 3 way switch between the front seats to adjust the shocks from inside the car (F45 1-yr only special suspension)?
Have you also changed the fluid in the rear diff?
