Questions regarding basic mods
Old Apr 18, 2002 | 12:29 PM
EricJ's Avatar
EricJ
Cruise-In III Veteran
Cruise-In IV Veteran
Default Questions regarding basic mods
I have a stock LT4 with 45k miles that I use for nice weather and cruising, and I want to do some basic mods to get a little more power. I need any suggestions you may have regarding these plans:
1. 160 thermostat
2. K&N with open lid
3. Cat back exhaust system. (BBTriflo is top choice)
Are there any other inexpensive mods that will help? Maybe a programmer for the computer? MAF foil? Fuel regulator? Inginition?
Any other suggestions with out going inside the motor?
Am I wasting my money?
Thanks for the help.
Old Apr 19, 2002 | 02:15 AM
Eric 96's Avatar
Eric 96
Default Re: Questions regarding basic mods (EricJ)
Hey EricJ, I am also a new LT4 owner. Mine already had the K&N filter, and Corsa pipes. I added the "open lid" to the K&N. I don't think I am going to mess with anything else. The car is a deam to dive, and I can't picture getting much more out of it...at least not that would justify the money spent.
Old Apr 19, 2002 | 03:04 AM
GM_96LT4's Avatar
GM_96LT4
Eric,
IMHO, It depends on what you want first.
If it is strictly performance, and your goal is to get more punch and the best bang for your buck, then I would invest in gears first.
However, a good sounding exhaust system seems to wake up the car and the driver, even it there is not a horsepower improvement.
Glenn
Old Apr 19, 2002 | 07:55 AM
KJones409's Avatar
KJones409
I added a TB air foil for less than 50$ and think it was worth it.
KJones
95 coup 6 spd
Old Apr 19, 2002 | 10:32 AM
VetteBabe1's Avatar
VetteBabe1
Default Re: Questions regarding basic mods (KJones409)
If you do an Air Foil, K&N + cut lid, FPR (up the pressure a little and advance your timing...really needs to be tuned at the track), a good cap and rotor + good wires and plugs, and an exhaust system, you should be looking at a .5 sec or more gain in the quarter I would think. That is what all of that did for my 87 auto, and might work even better on the LT4. :cheers:
Old Apr 19, 2002 | 02:06 PM
vader86's Avatar
vader86
1. 160 thermostat
yes you can do a 160(most of us do), but it wont help much without a Power Programmer to turn your fans on earlier.
One thing LT4 owners like is going to 4.10 gears, youll love it.
DONT buy the airfoil, its a waste of money, but a regulator, better plug wires (MSD, Taylor...), then think about headers. After that youll have to go into the motor to change the cam and port the heads and intake.
Old Apr 19, 2002 | 02:28 PM
tdock's Avatar
tdock
K&N - Affirmative
Cut Lid - Affirmative
AFPR - Negative, I think I'd recommend just buying a pressure tester gauge ($40) and make sure your pressure is around 45psi with the stock FPR.
4.10's - Can't comment on this mod (yet)
Cat Back Exaust - Affirmative
160 thermo - Affirmative, with fans reprogrammed definitely
Air Foil - Negative
Old Apr 22, 2002 | 01:07 PM
EricJ's Avatar
EricJ
Default Re: Questions regarding basic mods (tdock)
Thanks for all the responses. The first thing Im gonna do is Thermostat, K&N and exhuast. Trying to decide between the Powereffects and the BBTriflo. The Triflo looks the best but I'm worried about the resonance that is talked about here so frequently. Think I'll skip on the Airfoil and the AFPR. Thanks again for all the feedback.
To Questions regarding basic mods
