I've been wanting to rebuild the L98 in my 85 for awhile now. With almost 150K on it, I feel its getting tired and I'd like a little more power, not to mention long term durability. It runs great now, but I don't want to get caught with my britches down later on if something drastic happens.
As far as I can tell, other than companies that sell rebuilt engines like Jasper, I haven't been able to find a true replacement long block. My GM guy told me they discontinued the L98 long block and the long blocks they do have are generally for carburation and not fuel injection and I'd have to swap out the cam, etc. However, this morning I found on Summit a short block, GM Performance 12556121. Its made for fuel injection and its a 4 bolt main instead of the stock 2 bolt. There is also no provision for a mechanical fuel pump either. Has anyone used this short block? I figure I can add a nice cam, rebuild my heads and add some headers and I can get some more ponies out of it. I'd like the keep the TPI though, sentimental reasons. I'm pretty sure I can do it under my budget of $2500.
The thing that sticks out is the 18 cc pistons. I ended up buying a new GM block for ~$800 from Pace (Summit sells it also) that came with a 4" finish hone and cam bearings installed. That way I could pick out exactly what I wanted. (forged,cc,etc...)
That sounds like an idea as well. Do you remember the part number for the block?
If your engine is running good now, why not pull it and rebuild it yourself?
It would be easy & cheap to rebuild since their is no damage and only wear. The machine shop does most of the work for you. If your able to pull the engine yourself, then your able to build the engine.
Many people sell books and videos on rebuild the SBC. It's not all that hard to do and will save you 100's over buying a remain.
and it will make a great project and hobby for you. I assume you have all basic tools for engine pulling and stand. I did it and most of the references are here. This forum and the Field Service Manual and you are in the ball park.
That's also one of my ideas. I just wanted to have a couple of options to explore and evaluate. Odds are that I will just rebuild what's there provided I can find the time.
You should seriously consider it. Ive only rebuilt one engine but I can't even explain the joy I got when I heard it crank up for the first time.
It was like the first time I had sex. I kept thinking everything was going to go wrong, then once it was over all I wanted to do was hit the highway!
The machine shops I talked to couldn't beat the price and you get a 4 bolt vs 2 bolt.
sad but true...i have been building street/race engines since i was a teenager in the 50's, everything from Daytona 24 hr L88 (finished the race) to snow plows...still have the tools/etc, must 'farm out' the heavy machine work, i can 'get close' to 'crate' $ if my labor charge is '0'
While playing around trying to do your own can be a learning thing and fun most times when it comes out Ok if youre a beginner is luck.
Lots to know and certain tools you should really have to double check everything.
Not really worth it cost wise to do your own anymore unless youve been at it a long time. For a DD the GM shortblocks are a good way to go.
