Headlight help.
Old Apr 22, 2011 | 12:40 AM
MikeNavarro's Avatar
MikeNavarro
Default Headlight help.
I own an 84 corvette. I'm having an issue with my headlights- the headlights go up and down, but the problem is that one of them does not stop running once it gets into position. The gears begin to grind. I had to unplug both in the on position, in order to save the the parts that do work. Any suggestions as to what it may be? A relay? Bad gears? I have no idea. Plz help.
Old Apr 22, 2011 | 12:50 AM
oldalaskaman's Avatar
oldalaskaman
order the gears , but order both the small and large cause till you take it apart you wont know which one you'll need. before I upgraded mine , the small gear on one ane the large gear on the other went bad, hope this helps, bob
Old Apr 22, 2011 | 12:58 AM
MikeNavarro
Thank you, I'm 17 and my dad bought me the car as a gift on condition that I learn the thing like the back of my hand. is this a difficult process?
Old Apr 22, 2011 | 04:16 AM
oldalaskaman
no, theres alot of info on this site about it, and these folks are always ready to nelp someone who wants to learn.
Old Apr 22, 2011 | 09:37 AM
JackDidley's Avatar
JackDidley
There is a limit switch in the motor that stops it. Yours is not working. These early ones are sort of a pain to fix, if you have the $$$ you can get a new one on ebay.
Old Apr 23, 2011 | 09:55 PM
MikeNavarro
aight ill look it up. im def gonna upgrade the gears in the process of fixing it, and ill look up on this as well. appreciate the help man.
To Headlight help.
