Does anyone know what or where to get a tool to remove the wiring pins from weatherpac connectors. I am trying to remove wires from plu for fuel pump relay on 87 Corvette to add head shrink where wire covering has shrunk. Thanks.
Mine is a piece of a small retractable antenna. Someday I will upgrade.
I went hi-class, Ground a very small screwdriver.
Actually I cheated. Before I repinned my ECM I went to a salvage yard, got a harness with the same type of connector, cut one pin apart then ground a very small screwdriver to slide in and release the pin.
